Painting Ultramarines
Just a quick question, i tend to cut some time, by basecoating my Ultramarines with an armypainter spray. Do i use Ultramarines blue (dark) or Navy Blue (lighter). I want to wash afterwards.. (i feel the answer, but wanna be sure before i spend money on it...)
Thanks in advance
https://bolterandchainsword.com/topic/231243-painting-ultramarines/
Personally I use the following
Undercoat black primer
I spray with Regal Blue as a basecoat
Spray from above with ultramarine blue
Wash with Asurman blue
Progressive brush highlights with ultramarine blue / white mix
So if you go with the above Id use the darker spray as a base and work up from there. If you wanted a quicker result you could just spray them ultramarine blue and then wash them with asurman blue or badab black then highlight.
I get this result
http://i51.photobucket.com/albums/f372/rbrewster101/Untitled-1copy-10.jpg
