Taranis Posted June 8, 2011 Share Posted June 8, 2011 As the writing says. I can't find the rules describing it. I know it's 6", but where to prove it. Please somebody help find it in the rules. I have tried the search function but it refuses FnP as its too short. Thanks in advance. Link to comment https://bolterandchainsword.com/topic/231608-sanguinary-priests/ Share on other sites More sharing options...
Angel of the Emperor Posted June 8, 2011 Share Posted June 8, 2011 Page 48 under Blood Chalice Link to comment https://bolterandchainsword.com/topic/231608-sanguinary-priests/#findComment-2786512 Share on other sites More sharing options...
Xenith Posted June 8, 2011 Share Posted June 8, 2011 Check the rules for transports. Measure the 6" range from the hull. Link to comment https://bolterandchainsword.com/topic/231608-sanguinary-priests/#findComment-2786598 Share on other sites More sharing options...
Taranis Posted June 9, 2011 Author Share Posted June 9, 2011 I have read the section about transports and still I can't find the exact part about powers/effects when being used by embarked IC's. There have been more than one thread on the subject but I can't locate them. I need a reference to the correct page/faq/codex? Codex BA doesn't cover the general rules. Link to comment https://bolterandchainsword.com/topic/231608-sanguinary-priests/#findComment-2786905 Share on other sites More sharing options...
Volcatus Posted June 9, 2011 Share Posted June 9, 2011 BRB FAQ, page 3. Q: Can a model use a psychic power that is not a PsychicShooting Attack if it is embarked in a transport vehicle? (p50) A: Yes. If the power requires line of sight, this is still worked out from the vehicleʼs fire points (this will count as one model shooting through that fire point if the power is used in the Shooting phase). If the psychic power does not require line of sight and has a range or an area of effect that is normally measured from the model using it, these are measured from the vehicleʼs hull, as explained in the Embarking section on page 66. You won't find a clearer reference. If a character with an aura-type ability/power/trinket/wargear is embarked in a transport, use the rules on page 66 for determining the range of the ability. Link to comment https://bolterandchainsword.com/topic/231608-sanguinary-priests/#findComment-2787282 Share on other sites More sharing options...
Taranis Posted June 9, 2011 Author Share Posted June 9, 2011 Thanks a million. Exactly what I was looking for. Case closed. :eek Link to comment https://bolterandchainsword.com/topic/231608-sanguinary-priests/#findComment-2787381 Share on other sites More sharing options...
