Dreadnought
A dred has 2 attacks as standard with one weapon arm and the dreadnought cc arm, if i replace the cc arm with a missile launcher does this have any effect on his number of cc attacks?
A dreadnought has 2 base-attacks (on his stat-line); so with a single DCCW (a single fist or 'cc arm') he has two attacks. Replacing that single DCCW with a non-CC weapon (in your example, a missile rack) will not reduce the number of attacks he has: he'll still have two attacks, per his stat line.
The only things that do change are that he'll be at Str 6 (no longer Str 10) and no longer disallow armor saves when pounding on infantry.
EDIT: Seahawk types faster than me.
https://bolterandchainsword.com/topic/231665-dreadnought/#findComment-2787185
