appiah4 Posted June 12, 2011 Share Posted June 12, 2011 Are they all the same height? If I use the Furioso plastic arms (which I own) on an AOBR body (which I will soon own) would they look out of place/too big? Link to comment https://bolterandchainsword.com/topic/231893-dreadnought-size-comparison/ Share on other sites More sharing options...
Mr Yellow Posted June 12, 2011 Share Posted June 12, 2011 GW does a lot of work using CAD these days, as far as I know they are all the same size. The only thing is that the arm lugs on the AOBR dread are bigger (or smaller) can't remember which way round it is. Either way a bit of light chopping is in order. Link to comment https://bolterandchainsword.com/topic/231893-dreadnought-size-comparison/#findComment-2789834 Share on other sites More sharing options...
Cain Tiberius Kondrad Posted June 12, 2011 Share Posted June 12, 2011 I know there is a small size difference between the arm pegs of the AoBR Dread torso and the Sockets of the arms from the Furioso. But the overal size of the models is the same. With a little work, they would look fine. CTK Link to comment https://bolterandchainsword.com/topic/231893-dreadnought-size-comparison/#findComment-2789952 Share on other sites More sharing options...
Red Fury Posted June 12, 2011 Share Posted June 12, 2011 They are the same height and they will look fine. I have FW arms on AoBR dreads and AoBR arms on a Furioso. The problem you will have is the hole in the Furioso arm is bigger than the peg on the AoBR torso. So you'll have to glue, magnetize, or something else, to attach the arms. Link to comment https://bolterandchainsword.com/topic/231893-dreadnought-size-comparison/#findComment-2789995 Share on other sites More sharing options...
