Mr Yellow Posted June 13, 2011 Share Posted June 13, 2011 **Just realised, thanks to my bad english, that you might confuse me with the true scaling legend that is Lamenter. Sadly I'm not. If an admin reads this can they please change the topic name to LamenterMarine's** This is my current WIP Mephy counts as, there are more photos in my main topic (and album), just follow the link in my sig. Comments and Criticism are welcome, it's still very wip so be gentle. Link to comment Share on other sites More sharing options...
Glendor Posted June 13, 2011 Share Posted June 13, 2011 Looks pretty good though maybe he should be stepping on something other than another space marines head... Also where did you get the left shoulderpad? Link to comment Share on other sites More sharing options...
Grotsmasha Posted June 13, 2011 Share Posted June 13, 2011 Attention seeker aye? but seriously, as I'm a sucker for anything TS, I'll be watching...... Cheers, Jono Link to comment Share on other sites More sharing options...
Mr Yellow Posted June 14, 2011 Author Share Posted June 14, 2011 @ GLendor, the shoulder pas is actually part of the arm from the legion of the damned box sergeant. In fact I just nicked the whole thing off mine. The rest of the model will probably be sacrificed on the altar of eagerness and become reincarnated as a chaplain. The helmet is just a foot rest as I wanted something that high to put under it, it was nearby. @Grotsmasha, I shall try not to disappoint Link to comment Share on other sites More sharing options...
Wicced Posted June 15, 2011 Share Posted June 15, 2011 looking good. i'm looking forward to how this continues. as for your topic name problem, you should be able to change the title by yourself. click the edit button in your first post and use "full edit" there you can change the title of the topic. Link to comment Share on other sites More sharing options...
subtlebrush Posted June 15, 2011 Share Posted June 15, 2011 Gah my weakness.... True Scale! Looks awesome so far. I'll definitely be watching. Link to comment Share on other sites More sharing options...
Mr Yellow Posted June 15, 2011 Author Share Posted June 15, 2011 Thanks Wicced, topic name modified appropriately. Now prepared to get weak at the knees, I have finished doing the bulk of work on his chest, though maybe some nipples are in order. Link to comment Share on other sites More sharing options...
Mr Yellow Posted June 16, 2011 Author Share Posted June 16, 2011 Right, so I'm pretty much done with this, unless you see any obvious things missing. I think i've had enough of working on (certainly today) as I can't be bothered to do a psychic hood, I may still. so, Front: Side: Other side: It is only the first step on the long road that is True Scale-vision but I am happy with the result in general, at least for next time I know what order in which I should sculpt detail. Link to comment Share on other sites More sharing options...
Grotsmasha Posted June 16, 2011 Share Posted June 16, 2011 The only thing that is seriously detracts from the mini is his right foot. I know it's gunna be a b**** to do, but end result will be totally worth it. The easiest way would be to carve away that foot and smooth the inside that leg, then from a second set of legs, remove the leg, salvaging the foot for use on your current mini, then a small amount of GS fill and your done-skies. Cheers, Jono Link to comment Share on other sites More sharing options...
