amuro_ray Posted June 14, 2011 Share Posted June 14, 2011 Hi All, Does an Independent Character with Orbital Strike, Joined by Inquisitor Coteaz, able to use it in the special "I've been expecting you" shooting phase ? Regards, Link to comment https://bolterandchainsword.com/topic/232091-ive-been-expecting-you/ Share on other sites More sharing options...
Chengar Qordath Posted June 14, 2011 Share Posted June 14, 2011 I would think so, since the normal treatment of ICs is that they count as part of the unit they're attached to whenever a special rule mentions a unit. However, it does occur to me that it might be a potentially hazardous combination; "I've Been Expecting You" has a 12" range, and an OSR always scatters the full 2d6, so your squad with Coteaz attached would always be within the OSR's scatter range. I'd be a bit wary of the possibility of nuking your own unit. Link to comment https://bolterandchainsword.com/topic/232091-ive-been-expecting-you/#findComment-2791746 Share on other sites More sharing options...
AlexHolker Posted June 14, 2011 Share Posted June 14, 2011 Do the GK orbital strikes still have something like the Barrage Bomb, that is unlikely to penetrate your own armour? Link to comment https://bolterandchainsword.com/topic/232091-ive-been-expecting-you/#findComment-2791767 Share on other sites More sharing options...
jeffersonian000 Posted June 14, 2011 Share Posted June 14, 2011 Attach Karamazov to Corteaz' squad, and target one of you own with "I've Been Expecting You". SJ Link to comment https://bolterandchainsword.com/topic/232091-ive-been-expecting-you/#findComment-2791813 Share on other sites More sharing options...
Chengar Qordath Posted June 14, 2011 Share Posted June 14, 2011 Attach Karamazov to Corteaz' squad, and target one of you own with "I've Been Expecting You". SJ I don't think you can do that; "I've Been Expecting You" only allows the player to target enemy units that deep strike. Link to comment https://bolterandchainsword.com/topic/232091-ive-been-expecting-you/#findComment-2791996 Share on other sites More sharing options...
Gentlemanloser Posted June 14, 2011 Share Posted June 14, 2011 I suppose really the next question is does movement count for "I've been expecting you"? The biggie is can the ORS 'fire' if Coteaz and all moved in thier turn? Can heavy weapons? Link to comment https://bolterandchainsword.com/topic/232091-ive-been-expecting-you/#findComment-2792015 Share on other sites More sharing options...
Chengar Qordath Posted June 14, 2011 Share Posted June 14, 2011 I suppose really the next question is does movement count for "I've been expecting you"? The biggie is can the ORS 'fire' if Coteaz and all moved in thier turn? Can heavy weapons? I would think movement doesn't count; it didn't for the very similar rule in the old Daemonhunter codex. Link to comment https://bolterandchainsword.com/topic/232091-ive-been-expecting-you/#findComment-2792037 Share on other sites More sharing options...
Reclusiarch Darius Posted June 14, 2011 Share Posted June 14, 2011 Karamazov Coteaz 12 x Crusaders for meatshield 3 x Warriors for target lock Tehehehehe...if the enemy Deepstrikes within 12" of Coteaz+friends, they get auto-hit by a Lance strike Link to comment https://bolterandchainsword.com/topic/232091-ive-been-expecting-you/#findComment-2792047 Share on other sites More sharing options...
DV8 Posted June 14, 2011 Share Posted June 14, 2011 KaramazovCoteaz 12 x Crusaders for meatshield 3 x Warriors for target lock Tehehehehe...if the enemy Deepstrikes within 12" of Coteaz+friends, they get auto-hit by a Lance strike You cannot. As already stated above, using Coteaz's "I've Been Expecting You" rule only allows you to target Enemy models. Karamazov's no-scatter rule must target a Friendly model, and thus cannot be used in conjunction with Coteaz's. DV8 Link to comment https://bolterandchainsword.com/topic/232091-ive-been-expecting-you/#findComment-2792053 Share on other sites More sharing options...
Lord Ragnarok Posted June 14, 2011 Share Posted June 14, 2011 KaramazovCoteaz 12 x Crusaders for meatshield 3 x Warriors for target lock Tehehehehe...if the enemy Deepstrikes within 12" of Coteaz+friends, they get auto-hit by a Lance strike I was thinking of doing Three plasma cannon toting servitors and 2 xwarrirors with plasma guns in a chimera. Link to comment https://bolterandchainsword.com/topic/232091-ive-been-expecting-you/#findComment-2792061 Share on other sites More sharing options...
Godhead Posted June 14, 2011 Share Posted June 14, 2011 That's what i'm going to run with Coteaz too plus one monkey. I had thought two.. but for points sakes I think I'm just going to drop down to two. Link to comment https://bolterandchainsword.com/topic/232091-ive-been-expecting-you/#findComment-2792434 Share on other sites More sharing options...
Demoulius Posted June 14, 2011 Share Posted June 14, 2011 ive been expecting you *insert lance strike from orbit* ;) Link to comment https://bolterandchainsword.com/topic/232091-ive-been-expecting-you/#findComment-2792706 Share on other sites More sharing options...
Niiai Posted June 16, 2011 Share Posted June 16, 2011 ive been expecting you *insert lance strike from orbit* :) Now that is what I call a welcome! Link to comment https://bolterandchainsword.com/topic/232091-ive-been-expecting-you/#findComment-2794324 Share on other sites More sharing options...
GrayF0x3813 Posted June 20, 2011 Share Posted June 20, 2011 KaramazovCoteaz 12 x Crusaders for meatshield 3 x Warriors for target lock Tehehehehe...if the enemy Deepstrikes within 12" of Coteaz+friends, they get auto-hit by a Lance strike I was thinking of doing Three plasma cannon toting servitors and 2 xwarrirors with plasma guns in a chimera. I did the 3 servitors and warriors with plasma in a chimera, its basically a mobile gun battery; and it is rather effective. (Just remember you still have to roll a d6 when you fire plasma cannons for "Gets Hot!") Link to comment https://bolterandchainsword.com/topic/232091-ive-been-expecting-you/#findComment-2798164 Share on other sites More sharing options...
