Depending on task...
Ultra fine detail 000 (eyes, or fine script)
Medium detail 00 (like highlighting)
Anything else can be accomplished with a lower grade brush. Something to keep in mind. All the brushes have the same tip so the actual detail they can paint is similar. the difference is the smaller brush is easier to maneouver around smaller spaces where the bigger brush holds more paint which allows for more consistency over longer strokes.
https://bolterandchainsword.com/topic/232228-brushes/#findComment-2793740
Thanks for the replies guys. I am not sure where I can get Winsor & Newton locally. Think I'll go with ArmyPainter until I can find the others.
Just a quickie ... I went with the standard W&N Series 7 brushes over their "miniature" range - as far as I can tell, the "miniature" ones have a shorter head, and that's it - the point isn't any finer.
The Series 16 brushes are also very good. I went with Series 7 sizes 000 to 0, and Series 16 sizes 1 & 2 (because they're cheaper :)).
W&N sell their brushes directly. I've also bought stuff from Heaton Cooper (Grasmere) in the past, although I think they're a little north from you.
https://bolterandchainsword.com/topic/232228-brushes/#findComment-2794158
Regarding where to buy locally... I'm all for supporting local stores, but after weeks of peregrination searching for another sculpting brush and some acrilyc inks... I'm gonna start going to the net.
I use Da Vinci (both synthetic and natural ones) and they are beyond my current painting level. Once I wear them out, I'll probably get WN7, allegedly the best you can get... but 10-15 Euros a piece, better get them when I can actually appreciate the difference!
As for miniature vs regulars... I agree with Firedrake's idea
https://bolterandchainsword.com/topic/232228-brushes/#findComment-2794170
Agreed - my nearest town has a large art college in it. I went through the phone book going through all of the art shops, trying to track down W&N brushes and/or brush soap. Only 1 shop had W&N brushes, or had heard of brush soap - from the reaction of the others, I'm sure they thought I'd made it up! Sadly, they've since closed down. :tu:
Sadly, mail order is often the easiest way of finding specialist items, although I normally look around locally first ...
https://bolterandchainsword.com/topic/232228-brushes/#findComment-2794238
Right the miniature line bristles are shorter allowing for more control over a smaller space. Less flex and all. Brush soaps are a must. Treated properly a good brush should last a lifetime which is important to consistency. Every brush has it's own personality to speak.
I'm still looking for a good replacement for my general brush. Currently that's my GW fine detail brush from 10 years ago. It's starting to let go. I admit I totally abuse it.
Some advice for those who are new. Use the biggest brush you can to get the job done. I've noticed a trend for new painters to use the smallest brush they can, myself included. For the TT you shouldn't need anything smaller than a size 0 brush.
https://bolterandchainsword.com/topic/232228-brushes/#findComment-2794475
