Nrthstar Posted June 16, 2011 Share Posted June 16, 2011 So stage 1 of painting pink foam is to coat it with something before using a spray primer on it to avoid death gas. I got that. So I went option B and coated my foam with cheap Apple Barrel black acrylic paint with repeated coats to seal it up. Looking at it though I don't see the advantage of priming it now too with some Krylon. So the question is, my rock wall terrain is painted black, what should I prime it before applying citadel paints to it? Is there an advantage I don't know about? Thanks -North Link to comment https://bolterandchainsword.com/topic/232280-advantage-of-priming-pink-foam/ Share on other sites More sharing options...
barry_hhh Posted June 16, 2011 Share Posted June 16, 2011 as long as there is no foam showing you should be fine , if you want some texture and in some fine sand with some cheap paint and brush that on , also if you really want to make sure its sealed , you can add some PVA glue in with the paint . Link to comment https://bolterandchainsword.com/topic/232280-advantage-of-priming-pink-foam/#findComment-2794028 Share on other sites More sharing options...
templarboy Posted June 17, 2011 Share Posted June 17, 2011 Are you really using citadel paints on terrain pieces? I use the really cheap stuff personally. Citadel paint is like $1000 dollars a gallon. Egad. Link to comment https://bolterandchainsword.com/topic/232280-advantage-of-priming-pink-foam/#findComment-2795079 Share on other sites More sharing options...
LoneSniperSG Posted June 17, 2011 Share Posted June 17, 2011 Are you really using citadel paints on terrain pieces? I use the really cheap stuff personally. Citadel paint is like $1000 dollars a gallon. Egad. ........ Yeah but... the only reason I own Scorched Brown is FOR terrain. Egh. I suppose you have a point though. Too bad that I used all our craft paint when I was a kid, and now I don't know where to find the stuff around me. Michael's doesn't have it. Link to comment https://bolterandchainsword.com/topic/232280-advantage-of-priming-pink-foam/#findComment-2795139 Share on other sites More sharing options...
