Interrogator-Chaplain Ezra Posted June 16, 2011 Share Posted June 16, 2011 Quick question. A Rhino with passengers attempt to tank shock. The player says it'll move 12 inches. After moving 6, it contacts and enemy unit and is promtly immobilised by a Death or Glory attack. What matter in the shooting phase? Actually moved distance or announced movement? Link to comment Share on other sites More sharing options...
Legatus Posted June 16, 2011 Share Posted June 16, 2011 Eh, I am not sure. I guess technically, the "speed" as described on page 57 is determined by how far the vehicle actually moved that turn. So I guess you can say that according to RAW the vehicle would then be allowed to fire. However, I feel that if the player "called" the distance in advance, but the vehicle is then stopped early, it still "moved at the high speed", but simply did not make it as far as it usually would have. I think RAW is closer to "can shoot", but I feel it should be "cannot shoot". Link to comment Share on other sites More sharing options...
thade Posted June 16, 2011 Share Posted June 16, 2011 I think RAW is closer to "can shoot", but I feel it should be "cannot shoot". Yep. To clarify: yes, the vehicle uses the actual distance moved to determine whether or not it can shoot. It may not be as weird as it sounds at first. Think on it this way: perhaps it's not the the speed alone that prevents the pilots or occupants from shooting, but also the fact that it is in motion. While in motion, the thing is shaking around something fierce so it's hard to lean outside and get a meaningful shot off. If it's stopped abruptly, well - it's stopped. Now you can fire, if there's still time left: i.e. the second inference I'm making here is that a move that covers enough distance takes more time than just the Movement phase. Time and in motion are awkward concepts here because they don't really fit in well with turn-based combat; but the implications are there and it helps me justify something that is otherwise silly. :) Link to comment Share on other sites More sharing options...
Interrogator-Chaplain Ezra Posted June 16, 2011 Author Share Posted June 16, 2011 Thank you, much appreciated! ;) Link to comment Share on other sites More sharing options...
