winterdyne Posted June 20, 2011 Author Share Posted June 20, 2011 To make the shield you'll need: Plasticard (about .5mm / .75mm thick is fine) Circle cutter Marking compass & pencil A candle A plastic ring, slighty larger than the diameter of the shield 'dome' A marble With the compass, mark the centre of the shield - and the diameter of the dome. Don't press the point right through the plasticard. Set the compass slightly smaller and mark out the inner diameter of the rim (away from the dome). Set the compass slightly larger than the dome diameter and mark out the outer diameter of the rim (about 3mm greater radius than the inside). Cut the rim with the circle cutter. You'll find it easier to cut the outer edge first, then hold the plasticard and rotate it against the circle cutter to cut out the inside. Work slow and careful, the circle cutter is sharp and your fingers will be close. Better to go round a dozen times than slip. File the inside with a round file, and smooth the outside edge with a bit of emery paper. Light the candle, and warm the plasticard over it. When it starts to go glossy, place it on the plastic ring (marked side up) and use the marble to form a shallow bowl. Ensure the bowl follows the circle you marked, with the centerpoint in the middle. Allow to cool. With the circle cutter trim the dome (similar to the inside of the rim). Glue it together with liquid poly cement. Link to comment https://bolterandchainsword.com/topic/232359-sanguinary-phalanx-chapter-master/page/2/#findComment-2798274 Share on other sites More sharing options...
Something Wycked Posted June 20, 2011 Share Posted June 20, 2011 I'm even more impressed to know that you didn't just find a shield bit somewhere, but handcrafted it. Bravo, sir. Link to comment https://bolterandchainsword.com/topic/232359-sanguinary-phalanx-chapter-master/page/2/#findComment-2798500 Share on other sites More sharing options...
winterdyne Posted June 20, 2011 Author Share Posted June 20, 2011 I would have used a shield bit if I could have found one. Marauder used to do them and they were lovely for all sorts of things. Made it instead in a fit of frustration! Link to comment https://bolterandchainsword.com/topic/232359-sanguinary-phalanx-chapter-master/page/2/#findComment-2798504 Share on other sites More sharing options...
ItCameFrom1994 Posted June 21, 2011 Share Posted June 21, 2011 Delicious. Solid GS work. Link to comment https://bolterandchainsword.com/topic/232359-sanguinary-phalanx-chapter-master/page/2/#findComment-2798691 Share on other sites More sharing options...
Nyustukyi Posted June 21, 2011 Share Posted June 21, 2011 Where di you get the shield or better yet how did you make it? Link to comment https://bolterandchainsword.com/topic/232359-sanguinary-phalanx-chapter-master/page/2/#findComment-2799076 Share on other sites More sharing options...
Nyustukyi Posted June 21, 2011 Share Posted June 21, 2011 Where di you get the shield or better yet how did you make it? Link to comment https://bolterandchainsword.com/topic/232359-sanguinary-phalanx-chapter-master/page/2/#findComment-2799077 Share on other sites More sharing options...
Stonedog Posted June 22, 2011 Share Posted June 22, 2011 HOLY Emperor! That's cool beyond words! Link to comment https://bolterandchainsword.com/topic/232359-sanguinary-phalanx-chapter-master/page/2/#findComment-2800555 Share on other sites More sharing options...
shan vener Posted June 23, 2011 Share Posted June 23, 2011 my mind was througholy (spelling?) blown. but was i the only one to look at that shield and think assassins creed? Link to comment https://bolterandchainsword.com/topic/232359-sanguinary-phalanx-chapter-master/page/2/#findComment-2800577 Share on other sites More sharing options...
Interrogator Stobz Posted June 23, 2011 Share Posted June 23, 2011 http://www.winterdyne.co.uk/maz/images/commissions/sanguinaryphalanx/chapter_master_flickr.jpg Heh, Heh, I only quoted you to get these pic into this page :cuss Epic work Winter'. And I don't mean 6mm ;) Link to comment https://bolterandchainsword.com/topic/232359-sanguinary-phalanx-chapter-master/page/2/#findComment-2800617 Share on other sites More sharing options...
Something Wycked Posted June 23, 2011 Share Posted June 23, 2011 Where di you get the shield or better yet how did you make it? Top post on this page has the answer to your question <_< Link to comment https://bolterandchainsword.com/topic/232359-sanguinary-phalanx-chapter-master/page/2/#findComment-2801570 Share on other sites More sharing options...
dizzy-xc Posted June 24, 2011 Share Posted June 24, 2011 That sword owns. The mini's face is awesome. I hate that model, just my own personal taste... seems space marines keep getting more bling and ridiculous as time goes on. Pretty soon we will see one wielding a kitchen sink. Love the paint. Edit, and that shield! Pure win. Link to comment https://bolterandchainsword.com/topic/232359-sanguinary-phalanx-chapter-master/page/2/#findComment-2801647 Share on other sites More sharing options...
winterdyne Posted June 25, 2011 Author Share Posted June 25, 2011 ... Pretty soon we will see one wielding a kitchen sink... ARE YOU LISTENING, Angry Marines players? If only I got a commission to do stuff like that... I could go mad.... mad, I tell you. The Angry Sink, Furious Power Toilet, and Force Step-ladder would come to play too. Link to comment https://bolterandchainsword.com/topic/232359-sanguinary-phalanx-chapter-master/page/2/#findComment-2802611 Share on other sites More sharing options...
Tzen Posted June 25, 2011 Share Posted June 25, 2011 Seriously very nice Winter! Link to comment https://bolterandchainsword.com/topic/232359-sanguinary-phalanx-chapter-master/page/2/#findComment-2802757 Share on other sites More sharing options...
