combi weapon /storm shield
Chef Wulfen
i have had my WL equipped with a storm shield but i was thinking of changing out the SS for a combi and wasnt sure if that is a smart move. i would like to hear your thoughts my brothers and sisters
combi-weapons are great! but remember... once you use up that one shot, your basically stuck with a normal bolter. Keep in mind when and where your going to use that one shot. To be honest, I think storm bolters are under appreciated in the game! they do just as great, if not better in most circumstances. There is all this hype about combi-weapons, and list online like the wolf guard load out on the Space Wolf blog, but really in the long run, once you use up your combi-weapon shot, your really losing out in the end. But that's just my honest opinion. With a storm bolter, you can keep going and going and going, better stats compared to a regular bolter, not to mention cheaper compared to combi-weapons. So I say, don't believe the hype! save your points where it's needed, and since this is for your Wolf Lord... anything goes! it all comes down to personal preference!!! storm shield is nice, but I've seen terminators go down by mass bolter fire!
--EDIT--
correction, I've seen both terminators and thunderwolf packs with storm shields go down by mass bolter fire :wacko:
--EDIT--
correction, I've seen both terminators and thunderwolf packs with storm shields go down by mass bolter fire :)
yea i was looking at the SB. yea i dont get into the hype really of all the combi weapons. just wanted some info. it it will help i can write up my WL
--EDIT--
correction, I've seen both terminators and thunderwolf packs with storm shields go down by mass bolter fire ;)
Had a game versus chaos daemons the other day, the three combi-meltas plus the three meltaguns I had in my 3 grey hunter squads took down 3 wounds each on skarbrand and the keeper of secrets in one turn of shooting and the regular bolters only just managed to finish them of. Combi-meltas are soooooooo worth it for only 5 pts.
here is the way i think ill be going wtih my Wolf Lord
Runic Rmour
Frost axe
Combi-plasma
WTN
WTT
Belt Of Russ
2 Fen Wolves
Thunderwolf mount
saga of the Warrior Born
This next load out is more or less to play a Space Hulk/or small game
Terminator Aromur
Thunder Hammer
Storm Bolter
WTN
WTT
2 Fen Wolves
Saga of the Warrior born
Runic Armour
Frost Axe
Combi-plasma
WTN
WTT
Belt of Russ
2 Fen Wolves(when having the transport room)
Saga of the Warrior Born
I'd use saga of the bear just in case your unit gets stuck in with something that can mash your Lord if he fails an invuln save. Warrior born, imo, is really good for when your going to be going for assault, with how you are equiping your lord I would guess your going for shooty, and as such, more survivability is going to serve you better.
he was more cc and i might change him back. i was just wondering if it was good to take a combi over a storm shield
Combi are more cost effective for WG...not so much for ICs (pay double what a WG does)
Also...when would you use the plasma instead of simply charging in for assault?
*EDIT* My mistake...thought this was always for a thunderlord...cavalry charge is same pending difficult terrain. Foot sloggin lord does have a rapid fire but no charge zone
If you really want plasma on your IC a plasma pistol goes much better with your frost blade
-A+1 for sword + pistol
-Can assault after firing
-May fire more than once
I find that the Combi-weapons on a WL is not the most effective use of his weapon load out, a shooty WL is a waste of points, that is what your WG RP or even a Battle Leader if you want the BS 5. A WL should be slammed into CC as quickly as possible so he can start making his points back.
A SS is a great piece of equipment, but I would follow with a Thunder Hammer or a Wolf Claw as you are already loosing the +1 attack for 2 CCW.
The perfect load out for a Wolf Lord depends on what unit you plan to put him with, their transport and their overall tactical implementation. My WL pretty much runs with a SS/TH, SotBeast or SotBear, WTT and Runic Armor. Nothing like going into the game the feeling of being able to take on anything your opponent has with a good chance of winning.
Followed very closely by SS/WC, SotW, WTT, RA, MB put him in the middle of a big slug fest and watch him mow down everything in his path.
thunder hammers always go last am i right with this rule?
They strike at Initiative 1 which, for intents and purposes, is going at the very least joint last with anything else that hits at I1.
ok thanks i more collect then play really. so i was just checking
