Olgerth Istaarn Posted June 21, 2011 Share Posted June 21, 2011 I got to thinking. TWC is a perfect or near-perfect Deathstar unit because it is fast, tough and has staying power - that is, it can take a couple lumps before models start dropping off and the unit's power diminishes. It can survive a hard encounter with acceptable losses and move on to another target with reasonable hopes of prevailing again. But what if there was no TWC? What other SW units work as good, resilient deathstars with respectable punch? Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/ Share on other sites More sharing options...
Max_Dammit Posted June 21, 2011 Share Posted June 21, 2011 No matter the points? 3 wolflords wolfs as pets and a wolfpriest would dammage something a bit they even can join some GH or wolfguard Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799113 Share on other sites More sharing options...
Iacton Qruze Posted June 21, 2011 Share Posted June 21, 2011 I'd put them in a max squad of BC. largest group of ablative wounds, 2 charge attacks each. If you give the WP SotH, and can cover hop, you're looking at a 3+ cover save as you slog across the board. Pretty rough, but also around 1000 points for everything... Could also take a WG unit, pay for the Arjac upgrade, and attach him to the BC unit as well... Which could upgrade a model to Lucas the Trickster if you're really feeling it. Wow... I actually like this unit. might build it sometime. ^_^ Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799116 Share on other sites More sharing options...
Max_Dammit Posted June 21, 2011 Share Posted June 21, 2011 Arjac with tda wolfguard with wolfclaw and shields is a nother one Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799124 Share on other sites More sharing options...
Simo429 Posted June 21, 2011 Share Posted June 21, 2011 If I weren't worried about points A crusader Ragnar a wolf priest Arjac and 10 wolf guards armed as differently as possible Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799184 Share on other sites More sharing options...
Lord Ragnarok Posted June 21, 2011 Share Posted June 21, 2011 How about that same setup Simo but using Logan instead of ragnar and the priest? Can make use of and his wounds to absorb wounds and preferred enemy. Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799196 Share on other sites More sharing options...
Olgerth Istaarn Posted June 21, 2011 Author Share Posted June 21, 2011 What's the point of arming wolfguards differently? They are each 1 wound, so no way to play musical wounds. Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799236 Share on other sites More sharing options...
Maximus-92 Posted June 21, 2011 Share Posted June 21, 2011 What's the point of arming wolfguards differently? They are each 1 wound, so no way to play musical wounds wolf guard unit of three different guys takes say, 4 plasma wounds and 2 saveable wounds, You double up the plasma wounds on two of them and take two armour saves on the third. if he passes one lives, while if you were al armed the same they would have all died. You dont need multiple wounds to be cheesy :mellow:. Just the other day in a game against two i saved a bunch of grey hunters using this technique when a unit of suits with a bunch of attached drones shot at them. More firepower is not always better. This is why clever players often opt not to shoot weapons which allow saves at the same time as weapons which do not allow them or even mix lots of high ap weapons in with low ap ones. Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799260 Share on other sites More sharing options...
Grey Mage Posted June 21, 2011 Share Posted June 21, 2011 Yup- variations allow for AP 2/3 wound stacking, wich can make alot of deaths just go 'poof'. Its nice. But yeah, 10 WG in a Landraider, or a smaller unit with a priest in it works just fine. You dont have to go hog wild to get good effect from WG. Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799404 Share on other sites More sharing options...
maverik_girl Posted June 21, 2011 Share Posted June 21, 2011 Ragnar + Wolf Guard + Lone Wolves + Wolf Priest Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799462 Share on other sites More sharing options...
Max_Dammit Posted June 21, 2011 Share Posted June 21, 2011 where doe the lonewolves fit in? Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799473 Share on other sites More sharing options...
commander alexander Posted June 21, 2011 Share Posted June 21, 2011 Logan+Long Fangs in drop pod. Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799474 Share on other sites More sharing options...
maverik_girl Posted June 21, 2011 Share Posted June 21, 2011 where doe the lonewolves fit in? in the front soaking up all the fire, ragnar + wolf guard + wolf priest, six inches back for the counter attack LOL it was just an idea Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799479 Share on other sites More sharing options...
hendrik Posted June 21, 2011 Share Posted June 21, 2011 i've actually fielded a unit of logan, 10 grey hunters, a runepriest and a wolf priest inside a landraider crusader. used relentless when they jumped out, rapid firing and casting JOTWW right into the enemy before charging in headlong. this unit ate through my opponents army using the landraider to redeploy fast Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799535 Share on other sites More sharing options...
MaveriK Posted June 21, 2011 Share Posted June 21, 2011 Logan+Long Fangs+Ulrik Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799545 Share on other sites More sharing options...
commander alexander Posted June 21, 2011 Share Posted June 21, 2011 Logan and Long Fangs work, but why add Ulrik? Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799573 Share on other sites More sharing options...
Quillen Posted June 21, 2011 Share Posted June 21, 2011 The one that works the best for me is what Simo said. Ragnar with 10 Wolf Gaurd tricked out a bit in a LRC. it gets there it kills and it moves on. It's always gotten more then it's points back. Ragnar dies alot thou. Still I win when he dies so it sorta works out ok. lol I also use Logan Grimar in a Pod with Long Fangs. 3 Heavy melts and 2 plasma cannons. I some times through a WG with TDA and a sheild or 2 Rune priests. It lands it kills the plasma kills then it moves across the board killing. Sometimes if I have the points I trick the Pack leader out for melee too. 3 to 4 melee death machines with 5 range death machines. Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799575 Share on other sites More sharing options...
MaveriK Posted June 21, 2011 Share Posted June 21, 2011 Logan and Long Fangs work, but why add Ulrik? Umm, because he looks cool, and he's there to play poker with the old guys. But I was thinking of Slayer's Oath, and Mentor.. I'd give Mentor to a plasma cannon Long Fang. Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799578 Share on other sites More sharing options...
commander alexander Posted June 21, 2011 Share Posted June 21, 2011 You would make a Long Fang WS 5? Why? Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799584 Share on other sites More sharing options...
MaveriK Posted June 21, 2011 Share Posted June 21, 2011 You would make a Long Fang WS 5? Why? because I like waiting for someone to take the bait like you did Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799585 Share on other sites More sharing options...
Quillen Posted June 21, 2011 Share Posted June 21, 2011 Um the Pack leader would be a better choice lol. =P Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799587 Share on other sites More sharing options...
MaveriK Posted June 21, 2011 Share Posted June 21, 2011 alright, no more joking around... my honest answer would be several Wolf Lords on bikes. BOOMSPEED Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799591 Share on other sites More sharing options...
maverik_girl Posted June 21, 2011 Share Posted June 21, 2011 You would make a Long Fang WS 5? Why? ignore the psychologist! he gets this way when bored at work! trust me, I'm use to it :lol: I still like the idea of a bunch of Lone Wolves in an apocalypse game :huh: Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799596 Share on other sites More sharing options...
commander alexander Posted June 22, 2011 Share Posted June 22, 2011 I like that idea to, but I still don't understand why, even if it was just some stupid trick. A WS5 Long Fang couldn't do anything in close combat. Give the mentor rule to a WG and put it with them. Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799629 Share on other sites More sharing options...
Blacksad Posted June 22, 2011 Share Posted June 22, 2011 10 grey hunters (2 melta, Mark, standard) Ragnar, Wolfpriest, Logan, Arjac in a landraider crusader. *starts drooling* Link to comment https://bolterandchainsword.com/topic/232666-viable-sw-deathstar/#findComment-2799634 Share on other sites More sharing options...
