Slider Da Feral Posted June 21, 2011 Share Posted June 21, 2011 I've been working with spray primers (both Citadel and Army Painter) trying to get my minis ready for painting. On the plastic minis though, it seems that they're not getting a good even coat, or if they are, then it's running down the legs, making it look like hammered @$$. Am I spraying too close to the mini, or do I really need to wash my plastic minis like I do dishes to fix this? Link to comment https://bolterandchainsword.com/topic/232686-spray-primer-question/ Share on other sites More sharing options...
Purdy81 Posted June 21, 2011 Share Posted June 21, 2011 if its running down the model, your far too close and spraying far to much at once. 20cm away is about the distance i spray from, and just move the can from left to right to get even coverage. let it dry. Turn the model and do the same again. It might need a couple of coats doing it this way but more thin coats are far better than one horrible thick mess. just remember your not trying to cover the model in one go Link to comment https://bolterandchainsword.com/topic/232686-spray-primer-question/#findComment-2799444 Share on other sites More sharing options...
Slider Da Feral Posted June 22, 2011 Author Share Posted June 22, 2011 Right. After running a metric conversion, I was holding the damn can too close. (Note to self "SELF!": Hold that spray primer can no closer than 8 inches from the mini.) Link to comment https://bolterandchainsword.com/topic/232686-spray-primer-question/#findComment-2799791 Share on other sites More sharing options...
Brother Nihm Posted June 22, 2011 Share Posted June 22, 2011 Also, It helps spraying in passes, using a few thin layers instead of one thick one. That way you can always build up to good coverage, whereas with the reverse, you're stuck with too much paint on the mini. Link to comment https://bolterandchainsword.com/topic/232686-spray-primer-question/#findComment-2799794 Share on other sites More sharing options...
