OobTheDoomlord Posted June 22, 2011 Share Posted June 22, 2011 Hello. Just a quick question; does anyone know if a standard predator's autocannon will fit into a Baal predator's turret? Thank you for your time. Oob Link to comment https://bolterandchainsword.com/topic/232721-baal-predator-cross-compatibility/ Share on other sites More sharing options...
Leonaides Posted June 22, 2011 Share Posted June 22, 2011 should do, since the underlying turret is the same... Tho i dont know how the metal cowling might affect that. Of course that assumes you use it. Link to comment https://bolterandchainsword.com/topic/232721-baal-predator-cross-compatibility/#findComment-2799989 Share on other sites More sharing options...
Elsven Posted June 22, 2011 Share Posted June 22, 2011 It will work on the plastic model, I know this from experience. Link to comment https://bolterandchainsword.com/topic/232721-baal-predator-cross-compatibility/#findComment-2800004 Share on other sites More sharing options...
ChaosDave Posted June 22, 2011 Share Posted June 22, 2011 Yes it will fit, you will have to trim them a little bit. I magnetized mine and can swap out an autocannon, TL lascannons or the TL assault cannons. Link to comment https://bolterandchainsword.com/topic/232721-baal-predator-cross-compatibility/#findComment-2800203 Share on other sites More sharing options...
OobTheDoomlord Posted June 22, 2011 Author Share Posted June 22, 2011 Excellent news! Thank you all for your time and responses. To the shops! Link to comment https://bolterandchainsword.com/topic/232721-baal-predator-cross-compatibility/#findComment-2800209 Share on other sites More sharing options...
