Jim Shady Posted June 24, 2011 Share Posted June 24, 2011 So we know Horus was found first and Alpharius was found last but where do we all think the rest of the Primarchs line up in being found? I've read that Dorn was the 7th Primarch to be found. Link to comment https://bolterandchainsword.com/topic/232862-which-of-the-primarchs-was-found-after-horus-etc/ Share on other sites More sharing options...
Billuriye Posted June 24, 2011 Share Posted June 24, 2011 http://www.heresy-online.net/forums/showthread.php?t=33659 Link to comment https://bolterandchainsword.com/topic/232862-which-of-the-primarchs-was-found-after-horus-etc/#findComment-2801743 Share on other sites More sharing options...
Jim Shady Posted June 25, 2011 Author Share Posted June 25, 2011 That's burst my gellar field :( Link to comment https://bolterandchainsword.com/topic/232862-which-of-the-primarchs-was-found-after-horus-etc/#findComment-2802509 Share on other sites More sharing options...
Iron_Adam Posted June 25, 2011 Share Posted June 25, 2011 its daunting looking to take all that info and sudoku it into an order. whose gonna do it? Link to comment https://bolterandchainsword.com/topic/232862-which-of-the-primarchs-was-found-after-horus-etc/#findComment-2802558 Share on other sites More sharing options...
Brannick Posted June 26, 2011 Share Posted June 26, 2011 1. Horus Lupercal 2. 3. 4. 5. 6. 7. Rogal Dorn 8. 9. 10. 11. 12. 13. 14. 15. 15. 17. 18. Alpharius/Omegon Most of the theories point to Peturabo being second and Angron being sixteenth of seventeenth - i'm leaving out the 'unknowns' to make life a little easier. Night Haunter 'seems' to have been found quite late on, along with The Lion. With Ferrus Manus likely being one of the early birds along with Fulgrim and The Khan. Anyway, ponderings ahoy! Link to comment https://bolterandchainsword.com/topic/232862-which-of-the-primarchs-was-found-after-horus-etc/#findComment-2803684 Share on other sites More sharing options...
Wolffan Posted June 26, 2011 Share Posted June 26, 2011 Leman Russ was seen by 13th company SW, he led them . At least, they think he was..... Link to comment https://bolterandchainsword.com/topic/232862-which-of-the-primarchs-was-found-after-horus-etc/#findComment-2803790 Share on other sites More sharing options...
Jim Shady Posted June 27, 2011 Author Share Posted June 27, 2011 You have to think first of all, about the planets closest to Terra then I suppose we have a rough idea then fill in the blanks with bits we've been given by the HH books. I can see Magus being in the first ten. Prospero was in alone in it's part of the galaxy but i'm sure i've seen a map of the universe with Prospero marked and it doesn't seem far away from Terra. Link to comment https://bolterandchainsword.com/topic/232862-which-of-the-primarchs-was-found-after-horus-etc/#findComment-2803873 Share on other sites More sharing options...
Koremu Posted June 27, 2011 Share Posted June 27, 2011 1. Horus Lupercal2. 3. 4. 5. 6. 7. Rogal Dorn 8. 9. 10. 11. 12. 13. 14. 15. 15. 17. 18. Alpharius/Omegon You can't do just 18. If one (or both) of the unknowns were discovered early on, then you'll throw Dorn's discovery (known to be 7th of 20) out of whack. Link to comment https://bolterandchainsword.com/topic/232862-which-of-the-primarchs-was-found-after-horus-etc/#findComment-2803882 Share on other sites More sharing options...
Student Of Dorn Posted June 27, 2011 Share Posted June 27, 2011 You can't just look at where the planets they came from is placed 'cause some came to the Emperor instead of him coming to them Link to comment https://bolterandchainsword.com/topic/232862-which-of-the-primarchs-was-found-after-horus-etc/#findComment-2804138 Share on other sites More sharing options...
Lord_Caerolion Posted June 27, 2011 Share Posted June 27, 2011 And, if I remember correctly, the Lion was found early on, despite being quite far from Terra. After all, this is warp travel we're talking about, so just because it's closer doesn't mean it's reached first. Some expeditions probably came out far further than they intended, having gone half the galaxy away, rather than just the next system. Link to comment https://bolterandchainsword.com/topic/232862-which-of-the-primarchs-was-found-after-horus-etc/#findComment-2804187 Share on other sites More sharing options...
Iron_Adam Posted June 27, 2011 Share Posted June 27, 2011 It's like sudoku, make a graph or use cue cards and re-order them according to the other forums info that's out there Link to comment https://bolterandchainsword.com/topic/232862-which-of-the-primarchs-was-found-after-horus-etc/#findComment-2804215 Share on other sites More sharing options...
Legionator Posted June 27, 2011 Share Posted June 27, 2011 And, if I remember correctly, the Lion was found early on, despite being quite far from Terra. After all, this is warp travel we're talking about, so just because it's closer doesn't mean it's reached first. Some expeditions probably came out far further than they intended, having gone half the galaxy away, rather than just the next system. The Lion was found one hundred and fifty years after the beginning of the Great Crusade. I think it was not so early. Link to comment https://bolterandchainsword.com/topic/232862-which-of-the-primarchs-was-found-after-horus-etc/#findComment-2804225 Share on other sites More sharing options...
facmanpob Posted June 28, 2011 Share Posted June 28, 2011 There are many many threads about this on other forums, and some of the highlights that I remember are: Perturabo was one of the earliest, and he was before Guilliman and Angron (from the short story After Desh'ea) Magnus was found early due to his presence in the warp (can't remember the ref) Fulgrim was found very early and travelled extensively with Horus in the early part of the crusade (ref: his flagship is 160 years old - from one of the HH novels iirc) The Lion was later on - about 50 years before the Heresy (Descent of Angels/Fallen Angels) Lorgar was found about 1/2 way through the Crusade (can't remember the ref) Most seemed to agree that numbers 2-6 contained Perturabo, Magnus, Fulgrim, Guilliman, although the exact order was debatable Hope that helps :P PS you need to increase your list to have 20 spaces, as most also agreed that the 2 lost Primarchs were also found at some point. So Dorn is 7th out of 20, and Alpharius is 20th. EDIT - spelling! Link to comment https://bolterandchainsword.com/topic/232862-which-of-the-primarchs-was-found-after-horus-etc/#findComment-2804979 Share on other sites More sharing options...
Aegnor Posted June 28, 2011 Share Posted June 28, 2011 He said he was leaving out the two unknowns deliberately. From TFH, Magnus was found before Lorgar. Link to comment https://bolterandchainsword.com/topic/232862-which-of-the-primarchs-was-found-after-horus-etc/#findComment-2804988 Share on other sites More sharing options...
facmanpob Posted June 28, 2011 Share Posted June 28, 2011 He said he was leaving out the two unknowns deliberately. Problem is though, he's got Dorn at number 7 - that only works if you include the 2 lost Primarchs, because if one of those was found before Dorn, then Dorn should be at number 6 if you ignore the lost Primarchs....if that makes sense ;) Link to comment https://bolterandchainsword.com/topic/232862-which-of-the-primarchs-was-found-after-horus-etc/#findComment-2805136 Share on other sites More sharing options...
Koremu Posted June 28, 2011 Share Posted June 28, 2011 Pretty certain I mentioned that in post 8... anyhow, the knowns are; 1. Horus Lupercal 2. 3. 4. 5. 6. 7. Rogal Dorn 8. 9. 10. 11. 12. 13. 14. 15. 15. 17. 18. 19. 20. Alpharius/Omegon What else can we put in where? Link to comment https://bolterandchainsword.com/topic/232862-which-of-the-primarchs-was-found-after-horus-etc/#findComment-2805338 Share on other sites More sharing options...
Brannick Posted June 28, 2011 Share Posted June 28, 2011 It seems to be all but widely accepted that Perturabo belongs at space #2. Link to comment https://bolterandchainsword.com/topic/232862-which-of-the-primarchs-was-found-after-horus-etc/#findComment-2805422 Share on other sites More sharing options...
