Green Devils Posted June 24, 2011 Share Posted June 24, 2011 So, I was at a "bazaar" that is done at our GW store occasionally a bit back, and I traded some AOBR orks for a squad of scounts (unassembled). These are my first scouts however, and he didn't have the instruction sheet. They are the same as regular space marines for the most part, but the shotgun and Heavy Bolter are throwing me for a bit of a loop. The arm for the Heavy Bolter has a little handle in his hand, but I can't figure out where it goes, and the wrists on the shotgun don't seem to match the wrists on the arms. Suggestions? Or really, if anyone knows where i can get a copy of the instructions. Link to comment https://bolterandchainsword.com/topic/232900-space-marine-scout-assembly/ Share on other sites More sharing options...
Gurth Posted June 25, 2011 Share Posted June 25, 2011 The left hand with handle for the heavy bolter goes on top of the weapon. Link to comment https://bolterandchainsword.com/topic/232900-space-marine-scout-assembly/#findComment-2802628 Share on other sites More sharing options...
greatcrusade08 Posted June 25, 2011 Share Posted June 25, 2011 So, I was at a "bazaar" that is done at our GW store occasionally a bit back, and I traded some AOBR orks for a squad of scounts (unassembled). These are my first scouts however, and he didn't have the instruction sheet. They are the same as regular space marines for the most part, but the shotgun and Heavy Bolter are throwing me for a bit of a loop. The arm for the Heavy Bolter has a little handle in his hand, but I can't figure out where it goes, and the wrists on the shotgun don't seem to match the wrists on the arms. Suggestions? Or really, if anyone knows where i can get a copy of the instructions. The shotgun arms and the bolter arms both use the same left arm to attach too.. they usually form a poor match up, the best you can do is to bend the shotgun arm a little, shave a little from the underside of the pad on the left arm and use some green stuff to hide any issues. Link to comment https://bolterandchainsword.com/topic/232900-space-marine-scout-assembly/#findComment-2802652 Share on other sites More sharing options...
