Working with Green Stuff
thade
So I dremelled off most of a pewter captain's arm and cut another terminator arm to fit...used green stuff to fill in the cracks. It looks okay for my first go. He's sitting at home now.
Here are my questions:
1. If I Simple Green/strip the model, that will eradicate the green stuff, yes? (i.e. if I want to start over) Pretty sure it will.
2. With the green stuff hard, can I file and trim it without too much worry?
I forgot to wash the model clean of release gel before doing all this work. <_< He might be clean, but I want to be sure before I base coat him.
3. Will soap & water have any effect on the green stuff (other than cleaning it)?
4. If there's release agent in there will it hinder the bond at all? He's pewter, the arm piece is plastic (not finecast). The arm is also pinned.
Thanks!
https://bolterandchainsword.com/topic/233170-working-with-green-stuff/
My greenstuffed models seemed to have survived the process. You shouldn't have any issues.
Define 'hard' - that depends on your mix, but trimming is easy - filing can be an issue if it isn't truely "hard".
I forgot to wash the model clean of release gel before doing all this work. :P He might be clean, but I want to be sure before I base coat him.
Use a mild dish soap (it has a degreasing agent) and you will be fine.
Thanks!
Release agent can hinder the bond - yes. But mild soap and warm warter will easily rectify the situation.
