Xenos Inquisitor
I was thinking about a interesting set up
A Xenos Inquistor with the Beam
With some Gun Servitors with Plasma Cannons or Multi-Meltas.
Two of the Weaponsmiths
4 Warriors with Hot shot Lasguns
in a Chimeria
its a weapons platform.
What is your thoughts about this?
https://bolterandchainsword.com/topic/233558-xenos-inquisitor/
The big problem I can see with that unit is that the range on the various weapons do not match up very well. Hot-shot lasguns are 18" max (and really want to be in rapid-fire range), Multi-meltas are 24" max, Plasma cannons are 36" max, and a Conversion Beamer really wants to be at least 42" away for max strength/AP.
Well I was thinking the weaponsmiths maybe able to get the increased range on the weapons too and the reason for the hot-shot lasguns is the punish those the get too close to the chimera. Its just a thought.
For a shooty unit I think that a Psycannon Ordo Malleus Inquisitor is probably better if you are mixing in Multi-melta servitors, Jokero, and Acolytes with Plasma guns. That way you are looking at everything with 24" range (36" if you roll the extra range), and everything being able to target the same targets. That said it is a little overkill as you can only fire 5 weapons out of the chimera to begin with.
Well if you have a Inquisitor with the Beam and 2 Gun Serivtor with Plasma Cannons and two Weaponsmiths you have two lascannons 2 Plasma Cannons and a Beam hitting form 48 inches with 3 and 36 inches with all 5. And that is without inceased gun sights.
I run a list with coteaz in a chimera with 3 plasma cannon servitors and 2 space monkeys along with Captain Ablative wound and his sidekick Buckey. I like this squad a lot. I've never gotten anything other than +1 armor save or +5i save from the monkeys. I was kind of blah at 1st about those results, but rolling a 3 up armor save vs overheats for my pc servitors is awesome, and coteaz sporting a 5 up invul was pretty nice vs an ork list as well. My henchmen owned some orks. It was crazy (space monkey heavy flamers were the real hero, but fun none the less).
