Land Raider Crusader help
Brothers,
I got a new Land Raider Crusader kit off the net. It is an older kit, and came with metal bits for the MM and the Hurricane bolter sponsons. Evidently, the kit was so new that when GW put it out, that it didn't come with any directions on how to put the metal hurricane bolter sponsons together.
Does anyone have the directions for assembly of a LRC in digital form or some step by step instructions to post here?
Thanks.
-Harold
https://bolterandchainsword.com/topic/233730-land-raider-crusader-help/
Dry fitting and lots of green stuff's the key with the old style crusaders, I've put two together and they're nothing but a pain I'm sorry to say. Also if you're going to be handling the tank often I would suggest getting the trusty pinning kit out. As for the actual putting together, if I remember correctly, stick the bottom of the sponsoon to the tank first, sort out the bolter/ammo feeds on the strange metal I bar thing (they wont fit that well) put that into the hole in the bottom of the sponsoon, put the top sponsoon on then attatch the camera thingy on top, patience is the key with this bit as resting the weight of this join on the top of the sponsoon will result in it all fallinf apart. Finally stick the bottom camera thingy onto the I bar's bottom.
