sniperhavens Posted July 10, 2011 Share Posted July 10, 2011 Does anyone know of a good dremmel tool for drilling out barrels and the bottom of those Scibor Torso's. Im looking for something affordable but effective. Link to comment https://bolterandchainsword.com/topic/233784-dremmel-tool/ Share on other sites More sharing options...
Watcher in the Dark Posted July 10, 2011 Share Posted July 10, 2011 Dremmel tools run at RPMs that are far too high to effectively drill out bolters and such. That level of RPM leads to breakage and melting. I would suggest a pin-vise for those applications. Link to comment https://bolterandchainsword.com/topic/233784-dremmel-tool/#findComment-2814776 Share on other sites More sharing options...
templarboy Posted July 11, 2011 Share Posted July 11, 2011 Definitely don't use a dremel for drilling out barrels. Your control will not be optimum. I only use my dremel on metal and to remove large amounts of plastic. Even then I have had the dremel get away from me and I have injured myself and torn up models. Link to comment https://bolterandchainsword.com/topic/233784-dremmel-tool/#findComment-2815199 Share on other sites More sharing options...
Chapter Master Ignis Domus Posted July 11, 2011 Share Posted July 11, 2011 I just use a regular drill with the thinnest drillbit I own. Link to comment https://bolterandchainsword.com/topic/233784-dremmel-tool/#findComment-2815207 Share on other sites More sharing options...
Ironwulf Posted July 11, 2011 Share Posted July 11, 2011 Does anyone know of a good dremmel tool for drilling out barrels and the bottom of those Scibor Torso's. Im looking for something affordable but effective. As has been mentioned before, drilling out barrels is probably best done with a pin vice ( a hand-drill, including small drill bits). As for a Dremel tool that is affordable but effective, I'd say take a trip to the local Lowe's/Home Depot/hardware store and do a bit of comparison shopping. Heck, even the Mart of Wal (Wal-Mart) carries a couple of different models, including replacement bits. It doesn't have to be anything special to get the job done. Link to comment https://bolterandchainsword.com/topic/233784-dremmel-tool/#findComment-2815282 Share on other sites More sharing options...
