Forté Posted July 10, 2011 Share Posted July 10, 2011 The past few weeks of fighting had been a test like nothing like Valdr had experienced before. Cultists of the ruinous powers had filled the air with such a mixture of scents that a younger wolf would have given up and used his helmet. Sickly sweet at one moment and putrid the next. The traitors seemed to be taking some kind of twisted pleasure in smelling so different and the things which they had smeared on their often semi naked bodies would easily turn the stomach of any mortal man.Luckily, Valdr was no mere mortal man but a Grey Hunter sporting the insignium of the Blooded Hunter. Even so, he was wishing that he had his helm right now. Just to muffle smells.The Bolter clicked empty as another cultist chest exploded, showering those behind in gore. One of the twisted cultists dropping to the floor behind the tattered form of the ex-PDF trooper and rubbing the entrails all over his body in some kind of ecstasy fuelled frenzy.Valdr slammed a fresh mag into his holy Bolter before pushing the smoking hot barrel into the face of another semi clothed, cultist. The scorching was received with a squeal of enjoyment, a mere millisecond before its head was pulped with a single round. They were far too close now.Asbjorn had already switched to his Bolt Pistol and Chainsword in readiment of the coming melee. Morten was firing his Bolter one handed into the crowd of cultists who had given up their lasguns in favour of crude hand weapons. Blades, clubs, chains and anything that could tear and rend flesh could be seen in their hands but they were just as happy using their hands. Even if ineffective against the Astartes mighty power armour.The ruin of a wall had served well to slow the cultists so as not to be overwhelmed by sheer weight of numbers alone but now it was the Wolves turn...Charging out from the ruins after the volley of grenades had made a clearing, the pack slammed into the crowd. Morten dealing the first blows with his axe, cleaving the first cultist he came to from shoulder to mid and unleashing a few rounds from his bolt pistol into a few more. The rest of the reduced pack followed suit. Outnumbered by at least ten to one, this was still good odds.Valdr had no use for weapons now, with the Wulfen threatening to take over. Punching the head off the first unfortunate cultist in reach, crushing the windpipe of the next with his forearm and slamming his forehead into a third, caving his skull in. Worst thing was the cultists appeared to like it. The cultists closed in. Asbjorn finding his sword arm caught with a hooked chain but he quickly despatched the body on the other end with a burst, taking down the two others following up behind him.The carnage continued for another ten minutes at most. Asbjorn and Morten turning to find Valdr crouched over the last cultist’s dead body having just torn its larynx out with his fangs.“You need to keep that wolf of yours in check” said Morten. His axe dripping with gore.Kjetil, Nils, Tormod and Arnborg came walking up the street from where they had attacked the rear of the crowd. “This is getting to be hard work. They just don’t care about their own lives. Throwing themselves at us like they do.” Tormod was the youngest of the pack and still had lots of combat to experience, even after his years as a Blood Claw.“It’s time to move” said Kjetil. “We need to get into position”.-Edit-Slight little re-write after reeding back again. Really should proof read before posting :mellow: Link to comment https://bolterandchainsword.com/topic/233788-a-short-tale/ Share on other sites More sharing options...
hendrik Posted July 10, 2011 Share Posted July 10, 2011 i like it whelp, but i'm not that sure about the wulfen. one doesn't simply turn wulfen that easy. remember turning wulfen is one of the things a space wolf fears. if you have a chance to read wolf's honour you should do it, it contains quite some information about the curse of the wulfen Link to comment https://bolterandchainsword.com/topic/233788-a-short-tale/#findComment-2814832 Share on other sites More sharing options...
Forté Posted July 10, 2011 Author Share Posted July 10, 2011 I'll be sure to check that one out. It's not full Wulfen. Only the mark of. Link to comment https://bolterandchainsword.com/topic/233788-a-short-tale/#findComment-2814852 Share on other sites More sharing options...
hendrik Posted July 10, 2011 Share Posted July 10, 2011 in short it comes down to the fact that once you've turned wulfen for once it is possible to return in your normal state but you won't be forever. in time, be it months, years or hundreds of years the wulfen will take over, a fate worse then death some might say. one could see if one was wolf bitten(eg turned into a wulfen once) because of the yellow eyes. since our codex doesn't really go in to depth of how the mark of the wulfen gets represented i tend to think of it as a mark a wolf priest applies to one of the warriors who's clearly struggeling with keeping the inner wolf at bay, most likely to warn his fellow warriors of the fact that the marked warrior might turn wulfen soon, note that's just my interpretation atleast since there is no physical sign whatso ever that could indicate a brother is turning wulfen Link to comment https://bolterandchainsword.com/topic/233788-a-short-tale/#findComment-2815092 Share on other sites More sharing options...
Forté Posted July 11, 2011 Author Share Posted July 11, 2011 I see your point on that one so I'll think seriously on where I go with it here. Link to comment https://bolterandchainsword.com/topic/233788-a-short-tale/#findComment-2815353 Share on other sites More sharing options...
hendrik Posted July 11, 2011 Share Posted July 11, 2011 just have a grey hunter or bloodclaw lose his chainsword and bolt pistol and have him use his fists, head,knees etc to bash in some skulls ^_^ this WIP by a member of the B&C came to my mind :( bashing some heads Link to comment https://bolterandchainsword.com/topic/233788-a-short-tale/#findComment-2815844 Share on other sites More sharing options...
Forté Posted July 11, 2011 Author Share Posted July 11, 2011 That's awesome. Really shows it. Feel sorry for the one on the floor ;) Link to comment https://bolterandchainsword.com/topic/233788-a-short-tale/#findComment-2815855 Share on other sites More sharing options...
hendrik Posted July 12, 2011 Share Posted July 12, 2011 i like it! :huh: Link to comment https://bolterandchainsword.com/topic/233788-a-short-tale/#findComment-2816807 Share on other sites More sharing options...
Forté Posted July 12, 2011 Author Share Posted July 12, 2011 i like it! :lol: Thank you :huh: Link to comment https://bolterandchainsword.com/topic/233788-a-short-tale/#findComment-2816818 Share on other sites More sharing options...
Zynk Kaladin Posted July 12, 2011 Share Posted July 12, 2011 Cultists are fun aren't they!? I love the violent imagry and the detail: "The Bolter clicked empty as another cultist chest exploded"... nice. MORE! Link to comment https://bolterandchainsword.com/topic/233788-a-short-tale/#findComment-2817026 Share on other sites More sharing options...
Grimtooth Posted July 12, 2011 Share Posted July 12, 2011 Cultists are fun aren't they!? I love the violent imagry and the detail: "The Bolter clicked empty as another cultist chest exploded"... nice. MORE! I like reading about the effects of ccw weapons, both normal and power, on cultists. :P Link to comment https://bolterandchainsword.com/topic/233788-a-short-tale/#findComment-2817032 Share on other sites More sharing options...
Forté Posted July 13, 2011 Author Share Posted July 13, 2011 Wow...thank you again. There will be more and with better proof reading before I post this time. Link to comment https://bolterandchainsword.com/topic/233788-a-short-tale/#findComment-2817213 Share on other sites More sharing options...
Grimtooth Posted July 13, 2011 Share Posted July 13, 2011 Bad font color is bad. Link to comment https://bolterandchainsword.com/topic/233788-a-short-tale/#findComment-2817578 Share on other sites More sharing options...
spjaco Posted July 13, 2011 Share Posted July 13, 2011 Good start on what looks like it could be made into a longer and even more enjoyable tale. Help yourself to an ale. Link to comment https://bolterandchainsword.com/topic/233788-a-short-tale/#findComment-2817592 Share on other sites More sharing options...
Forté Posted July 13, 2011 Author Share Posted July 13, 2011 Bad font color is bad. Can all be changed. Link to comment https://bolterandchainsword.com/topic/233788-a-short-tale/#findComment-2817738 Share on other sites More sharing options...
Forté Posted July 13, 2011 Author Share Posted July 13, 2011 Good start on what looks like it could be made into a longer and even more enjoyable tale. Help yourself to an ale. No pressure then ;) Link to comment https://bolterandchainsword.com/topic/233788-a-short-tale/#findComment-2817740 Share on other sites More sharing options...
spjaco Posted July 13, 2011 Share Posted July 13, 2011 One day I hope to have time to put up a tale of SW myself. Maybe one day. Link to comment https://bolterandchainsword.com/topic/233788-a-short-tale/#findComment-2817936 Share on other sites More sharing options...
Forté Posted July 13, 2011 Author Share Posted July 13, 2011 One day I hope to have time to put up a tale of SW myself. Maybe one day. I thought that (with my basic story writing), then did it. Now trying to follow it you lol. Link to comment https://bolterandchainsword.com/topic/233788-a-short-tale/#findComment-2817940 Share on other sites More sharing options...
