fenrir31 Posted July 10, 2011 Share Posted July 10, 2011 I was wondering if anyone has a tutorial on how to put studs on power armor and terminator legs lke the FW Space Shark character? I was wonder ing how people put cut the shapes and what material they may use. Any help would be most appreciated. Thanks! Link to comment https://bolterandchainsword.com/topic/233836-anyone-know-how-to-put-studs-on-terminator-legs/ Share on other sites More sharing options...
Grotsmasha Posted July 11, 2011 Share Posted July 11, 2011 The easiest way is to get some small (1 or 2mm) beads from a arts and craft shop and recess them into the armour by using a pin vice drill. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/233836-anyone-know-how-to-put-studs-on-terminator-legs/#findComment-2815184 Share on other sites More sharing options...
Chapter Master Ignis Domus Posted July 11, 2011 Share Posted July 11, 2011 I tend to roll green stuff into a small ball and chop it in half, then stick it on the legs. It's nice and simple. Link to comment https://bolterandchainsword.com/topic/233836-anyone-know-how-to-put-studs-on-terminator-legs/#findComment-2815186 Share on other sites More sharing options...
Brother Nihm Posted July 11, 2011 Share Posted July 11, 2011 This is not a tutorial and therefore it doesn't belong in the Tutorial Section. Topic moved. Link to comment https://bolterandchainsword.com/topic/233836-anyone-know-how-to-put-studs-on-terminator-legs/#findComment-2815329 Share on other sites More sharing options...
Tanhausen Posted July 11, 2011 Share Posted July 11, 2011 You know the Brita water filtering jars? The filter is full of small tiny balls... perfect for studding :) Link to comment https://bolterandchainsword.com/topic/233836-anyone-know-how-to-put-studs-on-terminator-legs/#findComment-2815558 Share on other sites More sharing options...
GreenSlime Posted July 11, 2011 Share Posted July 11, 2011 Grandt Line make plastic rivets in various diameters, I've used then to represent studs on power armour. You should be able to get them from good model shops. Link to comment https://bolterandchainsword.com/topic/233836-anyone-know-how-to-put-studs-on-terminator-legs/#findComment-2815882 Share on other sites More sharing options...
