gettothegone Posted July 15, 2011 Share Posted July 15, 2011 I have a 5 man squad of GK Terms. One of them has a rod. A warlock appears. A warlock uses disintegrator... a) Its super effective? b) It has no effect? Discuss. Link to comment https://bolterandchainsword.com/topic/234156-hot-rod/ Share on other sites More sharing options...
thade Posted July 15, 2011 Share Posted July 15, 2011 If this is a serious post (I assume it is) I'm afraid I'll need a bit more info. What is a "warlock" (I'm guessing it's Dark Eldar?) and what's the statline/effects chart on a "disintegrator"? Link to comment https://bolterandchainsword.com/topic/234156-hot-rod/#findComment-2819759 Share on other sites More sharing options...
gettothegone Posted July 15, 2011 Author Share Posted July 15, 2011 Serious A warlock would be like a jetlock with say a farseer that uses a S5/AP4 template. The argument is that the template attack is a psychic attack, but does not require psychic test. The rod *and I'm going from a brief reading here* protects the squad from being a target of psychic attacks. If I read this wrong, please let me know. But would that null that attack? I'm like THIS close to buying a whole world of GK models, and I'm just reading up and getting info before I make the jump. Link to comment https://bolterandchainsword.com/topic/234156-hot-rod/#findComment-2819764 Share on other sites More sharing options...
DantonTH Posted July 15, 2011 Share Posted July 15, 2011 What is Rod? You mean Null Rod from the daemonhunters codex? How they got null rod anyway if so? If there is something I don't understand I must beg you pardon. If you mean Null rod; I would say Disintegrator does not work as it is psychic attack anyway. Link to comment https://bolterandchainsword.com/topic/234156-hot-rod/#findComment-2819790 Share on other sites More sharing options...
dswanick Posted July 15, 2011 Share Posted July 15, 2011 Warlock PowersDestructor : Destructor is used in the shooting phase instead of firing a weapon. It works out like a normal shooting attack with the folowing profile: Range : Template S : 5 AP : 4 Assault 1 Null Rod : {{snip}} Furthermore, the bearer (and his squad) cannot be affected by psychic powers (friendly or enemy) in any way. Destructor has no effect. That said, a Grey Knight Terminator squad may not take a Null Rod. Link to comment https://bolterandchainsword.com/topic/234156-hot-rod/#findComment-2819807 Share on other sites More sharing options...
volrath8754 Posted July 15, 2011 Share Posted July 15, 2011 One of the inquisitors can I assume thats what he ment. Link to comment https://bolterandchainsword.com/topic/234156-hot-rod/#findComment-2819833 Share on other sites More sharing options...
thade Posted July 15, 2011 Share Posted July 15, 2011 One of the inquisitors can I assume thats what he ment. That had been my assumption as well; however the clarification did bear mentioning. Link to comment https://bolterandchainsword.com/topic/234156-hot-rod/#findComment-2819864 Share on other sites More sharing options...
Inquisitor Fox Posted July 15, 2011 Share Posted July 15, 2011 Regardless of the presence of a psychic test, it is a psychic power. A null rod (usually the province of an Inquisitor alone now) nullifies psychic powers. It's fairly cut and dry :mellow: You cannot use a psychic hood to nullify the power, as there is no psychic test, however a null rod works just fine (assuming the bearer of the null rod has joined the Grey Knight Terminators). Link to comment https://bolterandchainsword.com/topic/234156-hot-rod/#findComment-2819866 Share on other sites More sharing options...
thade Posted July 15, 2011 Share Posted July 15, 2011 Not sure I'd want a Null Rod with the terminators...unless I knew I was going up against Eldar. Link to comment https://bolterandchainsword.com/topic/234156-hot-rod/#findComment-2819870 Share on other sites More sharing options...
gettothegone Posted July 15, 2011 Author Share Posted July 15, 2011 I think I may be reading it wrong and thus the confusion. Mind you.. you've clarified both for me so all is good. Warding Stave is what I was thinking about... and this is completely different from a Null Rod. Thanks :P Link to comment https://bolterandchainsword.com/topic/234156-hot-rod/#findComment-2819886 Share on other sites More sharing options...
Inquisitor Fox Posted July 15, 2011 Share Posted July 15, 2011 That's correct, a Warding Staff / Stave would only function if the bearer was engaged in close combat (which they would not be from a Destructor power from an Eldar Warlock). However in that instance the bearer's armor save would suffice. A warding staff / stave would not help against say, a plasma gun or meltagun, as those are shooting attacks. It would help against a power weapon, power fist or thunder hammer as those are close combat attacks. It likewise would help against Monstrous Creatures. It helps against wounds from a failed perils test if the bearer of the staff / stave is engaged in close combat at the time of the test. Otherwise it bestows no additional psychic protection. Link to comment https://bolterandchainsword.com/topic/234156-hot-rod/#findComment-2819895 Share on other sites More sharing options...
gettothegone Posted July 15, 2011 Author Share Posted July 15, 2011 Right, as I was skimming through the Codex last night I confused the Null Rod with a Warding Stave. Then thought.... you could put one in each group...... Then thought how awesome that would be with all the psy type players here. :P Just got ahead of myself. Link to comment https://bolterandchainsword.com/topic/234156-hot-rod/#findComment-2819898 Share on other sites More sharing options...
jeffersonian000 Posted July 15, 2011 Share Posted July 15, 2011 Aegis should still work against the attack, with or without an Inquisitor w/ Null Rod. SJ Link to comment https://bolterandchainsword.com/topic/234156-hot-rod/#findComment-2820168 Share on other sites More sharing options...
Something Wycked Posted July 15, 2011 Share Posted July 15, 2011 Aegis should still work against the attack, with or without an Inquisitor w/ Null Rod. And be doubly effective (quadruple, really) if they're in range of a Dreadnought. Yummy psychic defenses we have. Link to comment https://bolterandchainsword.com/topic/234156-hot-rod/#findComment-2820175 Share on other sites More sharing options...
Hiro_Protagonist Posted July 15, 2011 Share Posted July 15, 2011 Aegis wouldn't do anything. No Psychic test for Destructor, so who cares if you've got a Ld penalty? Link to comment https://bolterandchainsword.com/topic/234156-hot-rod/#findComment-2820192 Share on other sites More sharing options...
Something Wycked Posted July 15, 2011 Share Posted July 15, 2011 Hah, got lost in the "psychic power" and forgot about the "doesn't roll" part ;) Link to comment https://bolterandchainsword.com/topic/234156-hot-rod/#findComment-2820217 Share on other sites More sharing options...
thade Posted July 16, 2011 Share Posted July 16, 2011 Yerp. Aegis is a no-go. Silly xenos and their shenanigans. Link to comment https://bolterandchainsword.com/topic/234156-hot-rod/#findComment-2820526 Share on other sites More sharing options...
Hackbar Posted July 18, 2011 Share Posted July 18, 2011 That's correct, a Warding Staff / Stave would only function if the bearer was engaged in close combat (which they would not be from a Destructor power from an Eldar Warlock). However in that instance the bearer's arImor save would suffice. A warding staff / stave would not help against say, a plasma gun or meltagun, as those are shooting attacks. It would help against a power weapon, power fist or thunder hammer as those are close combat attacks. It likewise would help against Monstrous Creatures. It helps against wounds from a failed perils test if the bearer of the staff / stave is engaged in close combat at the time of the test. Otherwise it bestows no additional psychic protection. Just a trivial side note, but depending on how you read the FAQ I think the warding staff save could also be applied to any Low AP blasts that happen to scatter onto your unit, so long as it is in combat. Link to comment https://bolterandchainsword.com/topic/234156-hot-rod/#findComment-2822133 Share on other sites More sharing options...
