biglou666 Posted July 16, 2011 Share Posted July 16, 2011 Hi guys, here is forgeworlds rather awesome new dreadnought. http://www.forgeworld.co.uk/New_Stuff/CONT...OUGHT_BODY.html but, i was wondering, its alot taller than the typical dread, and you can give the model two dccw. could it work as a dreadknight? what do you guys think? in my mind it looks kickass, and with the right stance, i think it could look perfect on the dreadknight base. but, its a bit expensive, and i want to see what you guys think of it. it would be just a tiny bit shorter than most knights, but i dont think that would trouble too many opponents :P thanks, all comments welcome ^_^ Link to comment https://bolterandchainsword.com/topic/234204-contemptor-dreadnought/ Share on other sites More sharing options...
thade Posted July 16, 2011 Share Posted July 16, 2011 The Dreadknight model is huge; I haven't seen them up next to one another, but I don't think the new dread is big enough. If he's not very very close in profile (height, width, visibility) you could be called out for modelling to advantage. :( Link to comment https://bolterandchainsword.com/topic/234204-contemptor-dreadnought/#findComment-2820528 Share on other sites More sharing options...
imperious Posted July 16, 2011 Share Posted July 16, 2011 I thought the same thing when I first saw it. I think it could work pretty well. Link to comment https://bolterandchainsword.com/topic/234204-contemptor-dreadnought/#findComment-2820749 Share on other sites More sharing options...
Liba terminatus Posted July 16, 2011 Share Posted July 16, 2011 I think they are roughly the same size if not the dread is slightly shorter. I wouldnt use as a dreadknight though as some people who play chaos frown upon the idea ;) I'd also find it confusing if you used it as a dreadknight while I had one as a dreadnought for my chaos marines... I think they are roughly the same size if not the dread is slightly shorter. I wouldnt use as a dreadknight though as some people who play chaos frown upon the idea :D I'd also find it confusing if you used it as a dreadknight while I had one as a dreadnought for my chaos marines... Link to comment https://bolterandchainsword.com/topic/234204-contemptor-dreadnought/#findComment-2820755 Share on other sites More sharing options...
BLACK BLŒ FLY Posted July 16, 2011 Share Posted July 16, 2011 I bought one to use for my Dreadknight. Can't wait til it arrives in the mail. :o G Link to comment https://bolterandchainsword.com/topic/234204-contemptor-dreadnought/#findComment-2820813 Share on other sites More sharing options...
DinoDoc Posted July 16, 2011 Share Posted July 16, 2011 I think they are roughly the same size if not the dread is slightly shorter.It's actually a noticeable difference in size.http://www.forgeworld.co.uk/Images/Product/AlternativeFW/xlarge/contemptor16.jpg Link to comment https://bolterandchainsword.com/topic/234204-contemptor-dreadnought/#findComment-2820913 Share on other sites More sharing options...
Son of Rawl Posted July 18, 2011 Share Posted July 18, 2011 I would use it as I simply cannot stand the Dreadknight model, the size itself just annoys me more than Wards fluff for it Link to comment https://bolterandchainsword.com/topic/234204-contemptor-dreadnought/#findComment-2821907 Share on other sites More sharing options...
thade Posted July 20, 2011 Share Posted July 20, 2011 If the Dreadknight and Contemptor are close in size but the DK is slightly taller, you could easily jack the Contemptor up on a rocky/taller-than-usual base to compensate. If it is the case they're closer in size than I first thought, I might go this route myself. :D I do, however, like the DK model. ;) Link to comment https://bolterandchainsword.com/topic/234204-contemptor-dreadnought/#findComment-2824391 Share on other sites More sharing options...
thade Posted July 21, 2011 Share Posted July 21, 2011 So, no...the Contemptor won't work as a DK out of the box. Consider the Dreadnoughts as reference points. http://www.forgeworld.co.uk/Images/Product/AlternativeFW/large/contemptor16.jpghttp://i633.photobucket.com/albums/uu55/Gibbo_the_Great/BetterDreadknight.jpg The DK towers over the Dreadnoughts. The Contemptor is not nearly tall enough, nor is its base large enough. http://www.bolterandchainsword.com/index.p...p;#entry2824753 Link to comment https://bolterandchainsword.com/topic/234204-contemptor-dreadnought/#findComment-2824759 Share on other sites More sharing options...
Son of Rawl Posted July 21, 2011 Share Posted July 21, 2011 Too be honest I think it would work perfectly as a DK counts as, but as they say haters going to hate Link to comment https://bolterandchainsword.com/topic/234204-contemptor-dreadnought/#findComment-2825080 Share on other sites More sharing options...
thade Posted July 21, 2011 Share Posted July 21, 2011 Too be honest I think it would work perfectly as a DK counts as, but as they say haters going to hate This goes beyond "haters gonna hate"; size profile (it's dimensions) are part of the abilities to points calculation. There are terrain pieces behind which you can hide the contemptor easily that the DK will be head and shoulders over; also the base is far smaller, so the Contemptor can fit thru smaller gaps and be engaged by less models (in massive tar pits). It's not hate. In many cases it's unfair to your opponent. Link to comment https://bolterandchainsword.com/topic/234204-contemptor-dreadnought/#findComment-2825088 Share on other sites More sharing options...
Liba terminatus Posted July 21, 2011 Share Posted July 21, 2011 I think they are roughly the same size if not the dread is slightly shorter.It's actually a noticeable difference in size.http://www.forgeworld.co.uk/Images/Product/AlternativeFW/xlarge/contemptor16.jpg I meant that the dread is slightly shorter then the dreadknight... :( Link to comment https://bolterandchainsword.com/topic/234204-contemptor-dreadnought/#findComment-2825139 Share on other sites More sharing options...
Forcystus Posted July 21, 2011 Share Posted July 21, 2011 http://2.bp.blogspot.com/-p5ShuGXBpQE/TYDQW8gABnI/AAAAAAAADqs/FAcIgagWyxs/s1600/haters+gonna+hate+GK+grey+knight+dreadknight.jpg Link to comment https://bolterandchainsword.com/topic/234204-contemptor-dreadnought/#findComment-2825185 Share on other sites More sharing options...
biglou666 Posted July 22, 2011 Author Share Posted July 22, 2011 forcystus, that pic made my day xD @ thade, its my intention to buy the oval valkyrie/ dreadknight sized bases for my contemptors. Considering that helpful comparison pic (thanks btw) i would probably add a considerable amount of bulk to the bases, with some nice scenery to get them up to a similar size :D i wouldnt be using them in tournaments, unless it was a friendly one. I just want dreadknights that dont make me feel a bit ill when i look at them :P Link to comment https://bolterandchainsword.com/topic/234204-contemptor-dreadnought/#findComment-2826049 Share on other sites More sharing options...
