Ammo-feed for pa Grey Knights, like this?
Not a fan of the Mags, so I was thinking of a return to the design of the metal PA GK.
They had these ammo feeds running to their backpacks.
Tried this:
1. ( lacking the light even with a bright blue sky on a sunny day, shot in night-shot mode so a bit greenish...)
2. ( yes, the barrel was drilled after the photos taken.)
http://images.dakkadakka.com/gallery/2011/7/16/247455_md-Space%20Marines%20Grey%20Knights%20Wip,%20Warhammer%2040,000.JPG
http://images.dakkadakka.com/gallery/2011/7/16/247456_md-Space%20Marines%20Grey%20Knights%20Wip,%20Warhammer%2040,000.JPG
If i add such scraps of plastic and paint them accordingly, could I evade sculpting as greenstuff and its relatives and I hate each other with a passion?
Do you think the size is correct?
Any better idea?
T in A
Brother Hans-Heinrich
There are various belt feeds both in and outside of 40k. You could use one of them and make a press mold for greenstuff. The other advantage besides the obvious is anything you cast up with this using greenstuff would be slightly flexible. Never done anything like this so I can say for sure, but I would guess 2 to 3 hours of curing, maybe more before you remove it from the mold, position it and glue with superglue, trim if needed. (make it extra long, you can always cut bits off much easier than you can add it on).
Something like a heavy bolter feed would look good but in that case, might be slightly too large.
