Chengar Qordath Posted July 21, 2011 Share Posted July 21, 2011 Frag grenades anyone? DCA says no. Easy fix: don't be a goofball and assault your DCA into units in cover- use the regular Grey Knights in the list for that, or just shoot that unit down. :P Edit: I mean, heck, if you want to use that line of logic, where one failing is enough to disqualify a unit, then the Eversor discussion was over a long time ago :cuss Or run your DCAs out of a Crusader or Redeemer. Link to comment https://bolterandchainsword.com/topic/234284-eversor-assassin/page/2/#findComment-2825761 Share on other sites More sharing options...
Something Wycked Posted July 22, 2011 Share Posted July 22, 2011 Very true, Chengar, but I didn't want to go there because the vehicle alone is worth about two Eversors all by itself :rolleyes: Link to comment https://bolterandchainsword.com/topic/234284-eversor-assassin/page/2/#findComment-2825803 Share on other sites More sharing options...
Sanct Posted July 22, 2011 Share Posted July 22, 2011 Easy fix: don't be a goofball and assault your DCA into units in cover- use the regular Grey Knights in the list for that, or just shoot that unit down. Edit: I mean, heck, if you want to use that line of logic, where one failing is enough to disqualify a unit, then the Eversor discussion was over a long time ago :D Nicely out of context but it's really just a bonus to the mentioned 'single model in terrain' idea. Also depending on the terrain i don't always get the choice to not assault a unit in cover (destroyed tranports jump to mind) Link to comment https://bolterandchainsword.com/topic/234284-eversor-assassin/page/2/#findComment-2826110 Share on other sites More sharing options...
jeffersonian000 Posted July 22, 2011 Share Posted July 22, 2011 The major difference between the Callidus and the Eversor is that the Eversor is not commited to an attack that cannot be completed on the turn he arrives. This opens up quite a few tactics and strategies that just cannot be used with a Callidus. While in the previously mentioned thread I stated my dislike of the Callidus' current rules, I find the Eversor's current rules slightly better than the previous edition and with no reduction in ability as was had with the Callidus. Tactically, I'd rate the Eversor as a better buy than the Callidus, but still not as good as a Vindicare. SJ Link to comment https://bolterandchainsword.com/topic/234284-eversor-assassin/page/2/#findComment-2826247 Share on other sites More sharing options...
