Edemia Posted July 17, 2011 Share Posted July 17, 2011 Hi guys, I just bought a can of Army Painter White Spray Primer today for the first time as I had heard a lot of good things about it. I'm not sure entirely what to expect, but when I primed the models, the finish came out chalky and textured - is this normal for these primers? Edemia Link to comment https://bolterandchainsword.com/topic/234347-problems-with-army-painter-spray-primer/ Share on other sites More sharing options...
Montuhotep Posted July 17, 2011 Share Posted July 17, 2011 GW spray cans also had this effect for awhile; I think the problem lies with the temperature at which you spray - something either too hot or too cold, I can't recall which. Someone else? Link to comment https://bolterandchainsword.com/topic/234347-problems-with-army-painter-spray-primer/#findComment-2821542 Share on other sites More sharing options...
Chapter Master Kanithon Posted July 19, 2011 Share Posted July 19, 2011 I've had this problem, I think the spray coat goes textured if it's too hot because the spray dries before it hits the model, or something like that. Although it could be because it's too cold or wet, either way, it has to be relatively dry to spray I believe... Link to comment https://bolterandchainsword.com/topic/234347-problems-with-army-painter-spray-primer/#findComment-2822608 Share on other sites More sharing options...
Mercadius Posted July 20, 2011 Share Posted July 20, 2011 I find it's usually a side effect because it's too hot: the primer 'dusts' as it settles on the mini. I undercoat in my back yard where its well ventilated but wait and spray my figures at night if its a sunny day. Link to comment https://bolterandchainsword.com/topic/234347-problems-with-army-painter-spray-primer/#findComment-2824193 Share on other sites More sharing options...
