91Viper Posted July 19, 2011 Share Posted July 19, 2011 What is more effective? a) A Vindicare with turbo rounds or a Psyrifleman Dread at taking out armor; and :tu: A Vindicare with turbo rounds or a Psyrifleman Dread for killing MEQ? I see many lists with two Psyriflemen and not one with two Vindicares... was wondering if a mathhammer would help solve the offensive question. You then have to ask yourself which will live longer Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/ Share on other sites More sharing options...
Deathlok33 Posted July 19, 2011 Share Posted July 19, 2011 Not sure how to help, just noticed you can't bring 2 of the same assassin. Thats all i have to add =) Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2822661 Share on other sites More sharing options...
Something Wycked Posted July 19, 2011 Share Posted July 19, 2011 Psyfleman against AV12: Shots: 4 Hit Chance: 88.89% Hits: 3.556 Glancing Chance: 16.67% Glancing Hits: 0.593 Penetration Chance: 33.33% Penetration Hits: 1.185 Shaken: 0.494 Stunned: 0.296 Weapon Destroyed: 0.296 Immobilized: 0.296 Wrecked: 0.198 Explodes: 0.198 Psyfleman against AV14: Shots: 4 Hit Chance: 88.89% Hits: 3.556 Glancing Chance: 16.67% Glancing Hits: 0.593 Penetration Chance: 0% Penetration Hits: 0 Shaken: 0.296 Stunned: 0.099 Weapon Destroyed: 0.099 Immobilized: 0.099 Wrecked: 0 Explodes: 0 The Psyfleman is GREAT against AV 12 and lower; the Vindicare is GREAT against high AV values. You wouldn't use the Turbo Penetrator for killing MEQ unless it was a character without Invuln; you'd use Hellfire for the 2+ to wound normal MEQ, or Shield Breaker if it was a character with Invuln. The Psyfleman stands a good chance of inflicting four wounds, but the MEQ stands a good chance of making all of those armor saves. The Vindicare is almost guaranteed to kill a non-character MEQ with one shot, but that is the maximum potential- one death. Said another way, the Psyfleman will have a low average of deaths inflicted, while the Vindicare will have a steady average of about 1 per shot. Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2822673 Share on other sites More sharing options...
itsuperslug Posted July 19, 2011 Share Posted July 19, 2011 Vindicare - can kill most armour in 1 shot OR kill 1 guy Psyfleman - can kill most transports (AV 12 or lower) OR up to 4 guys Vindi for heavy tanks (better pen), psyfleman for MEQ (more shots) I go to battle with 1 of each Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2822819 Share on other sites More sharing options...
Drachnon Posted July 19, 2011 Share Posted July 19, 2011 Lets see if I can do the math for the Vindicare: DISCLAIMER: Rending is not part of these calculations as I have no clue how to add it to this formula. AV12 To hit: 91.67% Damage chances: Fail: 5.40% Glancing chance: 4.32% Penetrate chance: 90.28% Results if glance: (-2 from glance +1 from ap1) Shaken: 33.33% Stunned: 16.67% Weapon Destroyed: 16.67% Immobilized: 16.67% Wrecked: 16.67% Explodes: 0% Results if penetrate: (+1 from ap1) Shaken: 0% Stunned: 16.67% Weapon Destroyed: 16.67% Immobilized: 16.67% Wrecked: 16.67% Explodes: 33.33% Moar! calculations: 1(shots)*0.9167(to hit)*0.0432(glance)* result chances= Shaken: 0,0132 Stunned: 0,0066 Weapon Destroyed: 0,0066 Immobilized: 0,0066 Wrecked: 0,0066 Explodes: 0.000 1(shots)*0.9167(to hit)*0.9028(glance)* result chances= Shaken: 0,0000 Stunned: 0,1379 Weapon Destroyed: 0,1379 Immobilized: 0,1379 Wrecked: 0,1379 Explodes: 0,2759 After adding results together: Shaken: 0,0132 Stunned: 0,1445 Weapon Destroyed: 0,1445 Immobilized: 0,1445 Wrecked: 0,1445 Explodes: 0,2759 Conclusion: If my math is correct the vindicare is still slightly better at destroying (explodes + wrecked results) AV12 targets when compared to Something Wycked's calculation. I might do AV14 later however results might be less acurate here as rending is more beneficial against such targets (against AV12 the chance of the rending being wasted is pretty large) EDIT: When looking at averages I can say that rending increases the result by 0.667 per die rolled which is 2.67 for 4 dice. Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2822868 Share on other sites More sharing options...
Toasterfree Posted July 19, 2011 Share Posted July 19, 2011 Comparing apples to fruit flys. Dreads are a different beast. You can take them for weight of fire, may not always kill 4 guys, may not kill any, but s8 kills obliterators dead if they fail hence weight of fire. Can the vindicating kill one dead? No. Ok then. Can a dread wreck av14? No, but it can :lol: up some av13. Will you always face a toon with an invulnerable? Yes so the vindi has a role there as well as sniping out sgts and heavy weapons or special ccw etc, can a dread? No. Best viable option? Take one of each and double on the dread for weight of fire. Then who cares about the mathhammer, you have a role for each unit that it will excell at, and we are asking this to increase our post count. Just sayin Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2822928 Share on other sites More sharing options...
thade Posted July 19, 2011 Share Posted July 19, 2011 You did ask specifically for mathhammer. Now that that is covered... These two models serve different purposes. Psi-riflemen Dreads are intended to pop light armor/APCs at extreme range (36-48") while a Vindicare gets one shot at 36" He's got awesome Armor pen, but only one roll on that damage table. Can he pop that armor? Likely. Should he? In my mind he's got a much better usage: I can allocate his wounds. What can the Vindicare do that the Rifleman cannot? He can pick off annoying buried Power Fists/Klaws so your knights can charge in without a care in the world. 2+ armor saves go a long way. :P If I did field a Vindicare, that is what I'd use him for: to pick off buried PWs for my Paladins. The fact he can feasibly kill a Land Raider pilot is just a (very nice) bonus. Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2823092 Share on other sites More sharing options...
chaplainmeliadus Posted July 19, 2011 Share Posted July 19, 2011 but s8 kills obliterators dead if they fail hence weight of fire. Can the vindicating kill one dead? No. Actually, doesn't an Obliterator only have 2 wounds? And the turbo-penetrator doubles wounds, so if it fails its invun, it will be dead, yes? Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2823486 Share on other sites More sharing options...
Liba terminatus Posted July 19, 2011 Share Posted July 19, 2011 but s8 kills obliterators dead if they fail hence weight of fire. Can the vindicating kill one dead? No. Actually, doesn't an Obliterator only have 2 wounds? And the turbo-penetrator doubles wounds, so if it fails its invun, it will be dead, yes? Yup I have to say though the vindicare is one hell of a bullet magnet. But hey haters gonna hate when they see what he can do Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2823492 Share on other sites More sharing options...
breng77 Posted July 20, 2011 Share Posted July 20, 2011 As far as shooting at MEQ the Vindicare kills one guy 76% of the time (assuming no invul). The dread kills one guy 98% of the time (He averages around 3 wounds, on average marines will fail 1). The dread does have more of a range 76% of the time the Vindicare kills one guy the other 24% of the time he kills no one (it is important to not he kills one guy of your choice). The dread does have the chance to kill no one, or he could kill 4 guys, or any where in between (it is not all that likely as all the other possibilities fit into the last 2%, for example the dread will miss all four shots 0.01% of the time). Just for fun lets look at the Obilterator Example, the Vindicare kills 1 about 30.6% of the time, the Dread kills one about 49.3% of the time. Again the Vindi can pick out a 2 wound IC, or the apothecary in a paladin squad, but the dread could potentially kill all 3 obliterators. I also see people rave about the invul save removing ammo (its nice sure, against 1 wound models with good invul saves, against other models with more wounds it is nice but it would take 2 turns to reliably take down said model) the dread does not ignore MEQ armor saves so Invul saves are irrelevant in this comparison. Against infantry the story is this, Vindicare is nice because you get to pick out your targets, but the best he will ever do is Kill 7 models in a game. The dread has a much higher chance to kill infantry (possibly up to 28 models), but simply through straight allocation. Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2823947 Share on other sites More sharing options...
Brother Nihm Posted July 20, 2011 Share Posted July 20, 2011 but s8 kills obliterators dead if they fail hence weight of fire. Can the vindicating kill one dead? No. Actually, doesn't an Obliterator only have 2 wounds? And the turbo-penetrator doubles wounds, so if it fails its invun, it will be dead, yes? Yup I have to say though the vindicare is one hell of a bullet magnet. But hey haters gonna hate when they see what he can do Yeah he is, But I'd love to have an enemy Vindicare or Psyfle-dread fire on my Oblits, instead of my Rhinos. :P Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2823951 Share on other sites More sharing options...
Raus Posted July 20, 2011 Share Posted July 20, 2011 The dread kills one guy 98% of the time (He averages around 3 wounds, on average marines will fail 1). On average a marine will fail 1 save, yes, but that does not mean the dreadnought kills a marine 98% of the time. You need to consider that the average here takes into account all the times the marine player rolls more than 1 dice under 3. 3 dices give 216 (6^3) combinations. I don't have time to count them, but as you can see, the combinations not containing any 1 or 2 is considerably higher than 2% (Which would be a total of 4-5) http://homepage.smc.edu/mcgraw_colleen/mat...%20roulette.pdf Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2823973 Share on other sites More sharing options...
thade Posted July 20, 2011 Share Posted July 20, 2011 If the seven models that the Vindicare kills are all power fists, I say that's a win right there. :) Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2824015 Share on other sites More sharing options...
breng77 Posted July 20, 2011 Share Posted July 20, 2011 On average a marine will fail 1 save, yes, but that does not mean the dreadnought kills a marine 98% of the time. You need to consider that the average here takes into account all the times the marine player rolls more than 1 dice under 3. This is true but you also need to consider that you are generally shooting at more than 1 marine in which case those additional dice also kill marines so you need to look at the number of results in which no 1s or 2s are rolled, so while it is true that sometimes you will not kill any marines some times (8/216) you will kill 3, and sometimes you will kill 2. There are about 30% of combinations in which no marines die (64/216), equally though there are Which means that 152/216 times at least 1 marine will die, and 53/216 times that more than one marine will die. (On 3 dice) So it is 30% do nothing 70% kill at least 1 marine which breaks down to 3.7% kills 3 20.8% kills 2 45.8% kills 1. And none of that takes into account the fact that sometimes 4 shots from the autocannon will hit, so you cannot do the math for 3 dice. THe autocannon does .98 wounds to a marine, taking all factors into account which in effect means he will die 98% of the time. =4*(2/3+1/3*2/3)*5/6*1/3=.98 If you want to go for the closest math you can get you would need to look at the chances of each shot not wounding a marine (75.3%) then calculated that 32% of the time none of them will casue a wound, which leaves you with 68% of the time at least one marine will die. Much lower than my initial dirty math, but this does not take into account killing multiple marines as I indicated above. Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2824046 Share on other sites More sharing options...
Morollan Posted July 20, 2011 Share Posted July 20, 2011 If the seven models that the Vindicare kills are all power fists, I say that's a win right there. :rolleyes: Or Sanguinary Priests, Commissars, Librarians etc, etc. Vindicare is bloody useful to have. I'm practising for a doubles tournament at the moment and my teammate has one in his list. Blew up a minimum of 1 Land Raider every game as long as we got first turn. So that's nearly double his points cost back and, more importantly, a LR full of scoring infantry stuck out of position and having to footslog to objectives. Psiflemen dreads are also nice but we tend to face a lot of AV14 locally so the assassin is generally preferred. The two are very different though and not really worth comparing directly. Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2824125 Share on other sites More sharing options...
thade Posted July 20, 2011 Share Posted July 20, 2011 Psiflemen dreads are also nice but we tend to face a lot of AV14 locally so the assassin is generally preferred. The two are very different though and not really worth comparing directly. You can only take one Vindicare anyway...so why not also bring a Rifleman or two? Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2824133 Share on other sites More sharing options...
Morollan Posted July 20, 2011 Share Posted July 20, 2011 Psiflemen dreads are also nice but we tend to face a lot of AV14 locally so the assassin is generally preferred. The two are very different though and not really worth comparing directly. You can only take one Vindicare anyway...so why not also bring a Rifleman or two? Points. It's only 875 points each so even one of these models is a significant chunk of the army. Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2824137 Share on other sites More sharing options...
confused_gordy Posted July 21, 2011 Share Posted July 21, 2011 the main problem for the vindicare is that in 1/3 of his missions he wont be shooting till turn 2 (dawn or war), and only has 6+1d6 inches of board space he can get to before he starts shooting, to take advantage of cover. This majorly limits his options as to where he can be placed on the board, and where he can shoot things (as he only has a 36 inch range). the improved range, and moving while firing mitigates this for the dread, who is also less reliant on cover. (I assume that we are all packing a rhino or razor with search lights, or something similar in our lists to mitigate the turn 1 night fight). In addition to this, the dread is considerably more resilient than the vindicate (both die to high strength wounds/penetration 1/3 of the time, but the dread is immune to low strength), and is even more resilient in cover. Finally the dread is less effected by line of sight, as it has the amazing ability to move and fire, which the vinidicare doesn't possess (at ranges greater than 18") Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2824998 Share on other sites More sharing options...
breng77 Posted July 21, 2011 Share Posted July 21, 2011 While that is true remember that if positioning coming from your board edge is a problem you could outflank (and cost another turn of shooting. Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2825033 Share on other sites More sharing options...
Drachnon Posted July 21, 2011 Share Posted July 21, 2011 I've had great fun in lending my Vindicare a rhino of a strike squad. The idea is easy, the strike squad outside of the rhino start on the board (2 troops choices), have the rhino about 6" to 7" from the board edge, in your first turn the Vindicare jumps into the rhino which then drives of 12" preferably stopping somewhere within 2" of cover. From turn 2 onwards you can shoot from the harch, if the vehicle gets destroyed/wrecked you can either stick in the left wreckage/crater or jump into the cover. This gives you about 18" deployment, with the fortitude power you generally don't have to fear crew shaken and stunned results at all. Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2825064 Share on other sites More sharing options...
biglou666 Posted July 22, 2011 Share Posted July 22, 2011 I do like both the psyfleman dread, and the vindicare, they both have excellent practical use. the psyfleman is S8 insta killing most sm characters, messing up av <12, and thinning out hordes woth a decent amount of shots. the vindicare is massively reliable, his bs 8 and variety of ammmunition leding him much variety. the turbo penetrator round is amazing, in one game he took out all 3 of my oppenet's stormravens, in the space of 3 turns! if it was a straight up choice against an unknown opponent, then id have to go for the vindicare. his ability to take out vehicles alone makes him more than worth the points outlay :D however, in most games, both units end up in my list somewhere. :P Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2826066 Share on other sites More sharing options...
Reclusiarch Darius Posted July 22, 2011 Share Posted July 22, 2011 You kinda need both. Vindicare brings so much utility, and your only real hope of stopping a Landraider before it gets too close (you'll rarely catch it within psycannon range before it's disembarking Stormhammers into your face). PsyDreads can reliably damage anything not AV13/14, and if there are no armoured targets they can do reliably damage to infantry as well. Link to comment https://bolterandchainsword.com/topic/234469-psyriflman-dready-or-vindicare/#findComment-2826123 Share on other sites More sharing options...
