Techmarine helmet.
Arnil
On page 71 of the 5th Ed. Space Marine codex there is a drawing of a White Scars Techmarine with a strange looking helmet. Is there an actual helmet that looks like that in any actual sets? If not is there any tips you can give me for making my own. I have very limited green stuffing abilities but I do have green stuff.
https://bolterandchainsword.com/topic/235080-techmarine-helmet/
It looks like a normal helmet, to me, except with a very narrow respirator/"mouth".
Other helmets with narrow mouths include several of the Chaos heads and the Forge World Mk V power armour head... and a normal space marine head available in the tactical squad box- though none get quite this narrow...
If I were you, I'd either take "Space marine head A"
http://www.bitzbox.co.uk/images/space_marine_head_4_large.jpg
...and get two tiny pieces of greenstuff, and a good light overhead, and very carefully get two tiny dashes of greenstuff to put them into the sides; note there's four 'inny' grooves and three 'outy' grooves- just filling in the outer two 'inny' groves would narrow the mouth significantly, and overlapping a bit onto the 'outy' grooves would get it to about the same width as the mouth in the picture.
It's a very, very common bit to have lying around, and only needs a tiny amount of greenstuff, so don't worry about messing up; if you do, just buy another 10-pence online head!
Another vote for the Ravenwing tech helmet here.. It's got the unique shape and the big cog-shaped target finder on the side. Combine it with a Forgeworld torso, or with a Death Company torso that has the "iron apron" on the front, and you get a very nice "rough-forged" armor look.
I did two helmets using green stuff. I did sofacoin's idea but with a different head...it didn't look right I'll have to find that head...I think my girlfriend has some in her head bitz box... But I did start messing around with A razor blade and that head Dark Master recommended...I dug out an indent where the mouth grill would be the I filled it in with green stuff to the level a girll would be and cut slits in it...I'll get pics up when I can...looks cool
She called me last night with the revelation that she does in fact have that head. I have actually never bought a tac marine box so I didn't have it. I buy ravenwing sets for white scars. Actually the one she found was an older head, you can tell buy the color of the plastic, and it has a narrower grill than the one you suggested, I think it is just an older version of the same mark of helmet though cause it has the two Tubes on each side like the one you show.
