Needing some help.
I have a 2500 point tournment on Saturday and I need some help with an idea.
In my list I want to put:
Bjorn with Plasma Cannon
2 Rune Priests both with Choose of the Slain and one with Melta bombs
2 Venerable Dreadnoughts both with Lascannon and CCW arm with Stormbolter
4 Wolf Guard with Powerfist and Combi-melta
4 8 Grey Hunter Squad with melta gun, wolf standard, and Mark of the Wulfen in Rhinos
2 6 man Long Pack
One with 3 ML and 2 Lascannon
Other with 3 Heavy Bolter and 2 Plamsa Cannons
And I was thinking of a Land Raider if I had the points.
Would this be a good enough list?
https://bolterandchainsword.com/topic/235163-needing-some-help/
I was Just wondering what powers the rune priests have.
In the GH squads I would drop the wolf standards and add another GH in. Also, put a Plasma Pistol in each squad.
Put in a vindicator because of it's versatility.
Add some fen wolves with cyber wolf.
Put in some wolf scouts with a melta gun and a power weapon.
I think it's within the points range.
Hope I could help.
Hope I could help.
They both have Jaws and one has MH and the other has LL. The reason for 8 Grey Hunters is because with the Wolf Guard its 9 guys and I can put the Rune Priest in the Rhino with them.
If you're going to run the Priests in the rhinos, I'd recommend giving one of them storm caller.
Ok so for the other 2 GH squads I would put 1 more in instead of the Wolf Standards.
whats wrong with the Wolf Standard?
Wow. Where did all this wolf standard hate come from? It is probably the one piece of war gear the hunters should have besides a meltagun. It is only 10 points. Bottom line is take them. You are bringing rhinos, which means you have considered bringing the fight to the enemy at some point.
If you know you are going up against lots of MEQ's, swap the MotW for Power weapons. They will be more reliable. Or bring both.
Definitely consider A vindicator and/or Predator. Since you have a lot of long range fire already, consider the vindi and scouts to push your opponent away from the board edge, and towards that str10 pie plate. Or hide a Lone wolf behind the vindi and deny line of sight until he get in range to cause havoc.
