How much unpainted army do you own?
thade
Unpainted?
For my Blood Angels
Mephiston and Tycho are partially done
My Vanguard is mostly done.
1 10 man assault squad unfinished
1 Land Speeder still in box
1 Land Speeder, broken, needing repair and needs to be finished painting
Storm Raven still in box
3 Furiosos of various levels of completion.
10 Death Company mostly painted, a few still need a little work
1 Libararian unfinished
5 of the Space Hulk Terminators, unpainted.
For my Thousand Sons,
1 Aspiring Sorcerer, still in blister.
I think everything else is done.
I should probably say how much, in over ten years, I haven't painted. As of a month ago:
2 FULL Battle Companies
2/3rds of a Scout Company
2/3rds of a Veteran Company
Several vehicles from the Armoury with several techmarines, a couple dozen servitors and a few Thunderfires
A Chapter household
and several miscellaneous HQ characters/units towards another company.
not mentioning my large collection of Fantasy High Elves, 3 large LOTR armies, and several decent sized or larger forces for other gaming systems.
All put together, at least.
But, I have stopped buying the last couple months and have painted 4 tactical squads, 2 Rhinos, an assault squad, a JP chaplain, a Cassius counts-as, and a librarian in the last month. Nearly finished my Predator.
I'm hoping to get a Battle company done by years end.
1xAoBR Captain (primed)
1xLibrarian (primed)
1xChaplain (primed)
3xApothecaries (primed and base painted purple, trim unfinished)
2-3xTactical Squads (base painted purple, shoulder pad trim white, other trim unfinished)
4xRhino Chassis (most recently purchased)
4xSpace Marine Bikes
3xOrk Deffkoptaz chopped down and converted into space marine biker stand-ins
4xAoBR Tactical Terminators (I rarely field terminators, since I used
3xAoBR Dreadnoughts (primed)
5xkitbashed PVC drop pods
3xsquads of CCW assault/scout proxies
2xG.I. Joe Fliers as stormraven proxies
2xtechmarine proxies
And all the Orks that came from AoBR, because I don't play Orks.
I labeled things as proxies if they aren't specifically GW models, I use them in casual play, but they don't hold up in tourneys.
3 Armies:
Star Phantoms Space Marines (my most active project):
Painted: ~1400 points
Assembled but unpainted: ~1100 points
Unassembled: 55 points (one drop pod sitting patiently next to my hobby table)
Warhammer Fantasy Orcs and Goblins (second most active project):
Painted: 2500 points
Assembled but unpainted: ~1700 points, though a chunk of that is a new cockatrice and black dragon for Storm of Magic games
Unassembled: 90 points (30 night goblins)
Imperial Guard (my prior 40k army):
Painted: 3300 points
Assembled but unpainted: 700 points (two hellhounds and some infantry)
So total:
About 7200 painted
About 3640 product owned but unpainted
So around 1/3 of my total GW stuff in unpainted. Not too bad--having a mostly painted large IG army helps a ton.
I try not to run too much of a deficit, and never let it get to the "more unpainted than painted" point. But that's just me.
Cheers.
Too much way to much.
Seconded......Ultramarines 2nd Co - various stages, UM 1st Co - various, vostryan - getting there, IG co - built and primed, goff army - primed, speed freaks - still mostly in boxes, IG tank co - built, space wolf - built, grey knights - (draigowing) - mostly painted, BA jump army - built, partly painted.... Pretty much every army is 2000 pts+ and as you can see I have a short attention span........ohhh look at the butterfly......
But hey, I never get bored of painting a single colour!
Some of us probably shouldn't really think about this subject! It can lead to even more serious mental issues other than figmentia.
For me here's a brief run down of what I know I have painted:
169 painted marines and Inq mini's for 40k
343 painted mini's for other games and display
The unpainted:
For 40k I probably have 3 to 4 times as much still sealed in the box or unboxed complete sprues as I have painted. I should have almost enough to give me a Battle Company with options and more cool supoort things than you can shake a stick at if I ever get it all done.
My whole pile o lead/plastic for all things mini related takes up an old 40's pantry, a 32" tall 5 drawer storage unit, and a small 3 drawer one, and a stack of boxes about 2 foot high of boxes that won't fit out of sight somewhere else plus misc stuff stashed in and around my painting desk. 98% of that is either new in box and blister, or in bags to help conserve some space.
And since I consider bits intregal to building anything, My bits collection for marines alone is a stack of 40k vehicle boxes packed full that stands about 4 feet tall with 3 or 4 of the cheap larger sized plastic storage bins for the other 40k and fantasy bits.
It's a lot of stuff with the saving grace of knowing I did do it over a good bit of time so I consider myself at least semi sane. I do know people who have their whole basement full of un opened box upon box that make me look like a newbie.
I want to lend a sage bit of advice to everyone. The biggest complaint I hear from people about not painting their army is that they got it all assembled and are playing with it but when they want to paint there's so much to do they get intimidated and frustrated by how daunting it looks to complet it. My solution, try to keep the assembled stuff to a minimum, I personaly try for no more than 2 units worth assembled and waiting for paint at a time. Keep all unpainted models out of sight as much as possible. Put them in a drawer or a box, anywhere you can't see then. The only unpainted things you should have out is what you're working on. With only one unit out and being being worked on at a time you can keep focus better, as you work you will see progress with out measuring it against the amout of unpainted stuff to go, when your done leave this unit out to motivate yourself for the next. Before you know it your painted will outmumber your painted if you've stopped buying that is :HQ: in my case I keep about even.
Remember, Wargamer tradition dictates a man can not die till he's painted all he has. In my case I'm good till about 2250 I guess!
I would say about 97% of my stuff is unpainted. I love to build and convert minis but I hate painting. I have 16 years worth of Space Wolves (regular and 13th Co), Space Marines, Wood Elves, High Elves, Vampire Counts, Necromunda and Mordheim spread out over 2 tables, a few cases and a storage closet. Its probably never gonna get done.
I need to partner up with someone who loves painting but not building so I can build everything and then they can paint it...
Three Tactical squads, 6 Rhinos, Sternguard, Two Devastator Squads, a Razorback, a LR Crusader, Two Chaplains, two Assault Squads, annnnnnd a T-Hammer Terminator squad.
...oh my goodness I'm depressed. Everything is basecoated, though. Need some Sally green from my local Home Despot.
I've got about one whole company of Blood Angels with accompanying armor that are all in various stages of being done. Most of them still have their prime and basecoats showing. >>' I wish I could afford a proper airbrush. Not the (admittedly cool looking) GW hand flamer debacle.
I started in the original Rogue Trader days and as of right now I have 3 Terminators still being painted and 5 Sanguinary Guard (stand-ins for Vanguard Vets) which are assembled but not primed yet for my new Minotaur Chapter army, other than that I believe all of my marines are all painted which includes a small Crimson Fists force, about 1,000 points, about 4,000 points of Black Templars and maybe 5,000 points of my DIY Chapter the Crimson Lions. I also have about 11,000 points of Orks with all but 2 Deffkoptas and 5 Boyz are painted at the moment.
I also have 2,000 - 3,000 point armies of Dwarves, Empire, Tomb Kings and Ogre Kingdoms painted up for Fantasy.
OMG:cussBBQ....
Let's see...I have:
Assault on Black Reach box set
Three boxes of Assault Marines
Space Marine Captain
Chaplain Lemartes
Dante
Two squads of Thousand Sons
Two Terminator Chaos Lords/Sorcs
Chaos Sorcerer
Old edition Black Templar box with the metal scouts.
Out of all that...Only one lonely Tac Marine is painted up with another Tac and Termie undercoated white. I gave up on painting after finishing the Tac marine.
I think right now for me unpainted wise for armies I collect.
Grey Knights
3x Rhinos
1x Dreadknight
Object Marker
Paladin unit
Blood Angels
2x Storm Raven
Space Hulk
The Terminators do have paints on them but it more trying to finish them.
Daemons
Still need to buy a box of plastic Bloodcrusher, trying to phase out any metal models.
I think overall I have the above, some none 40k/power armour stuff. Other than that my armies tend to be fully painted. I might have a few things in boxies where I needed some bits for conversion or add the odd model due to new conversion idea in to one of my current armies, like my Space Wolves I just made a new LotD object marker after seen the Black Library new LotD novel.
But I alway aim to get into habit of getting armies painted in the spare hours I got when in my home. My friends comment it rare to see me with a un-painted army.
Armies I have that can be said on the fourm :lol: is Iron Warriors, Space Wolves, Iron Hands, Blood Angels, Grey Knights, Chaos Daemons. Then there a IW fleet & Space Wolf fleet for Battlefleet Gothic & then Space Hulk.
IP
I have a 4 level cabinet, two are full of Chaos, one is full of Loyalists, and the last has Orks,Guard, and other random stuff, plus my work station that has 20 CSM and 5 Dark Angels 95% is unpainted or just undercoated.
One day........they will ALL be painted...... :wub:
None :wub:
Then again I've donated my old Wolves (for the second time) as Forge World released full Heresy Era Armour kits and weapons and I want to represent it as best as possible.
Decided that I'm going to start with 25 marines (Five sets of MK IV armour) because I want a full running Blood Claw Pack and full Grey Hunter pack as the basis, everything else will be added and painted as acquired.
Hm. I'm new, started gathering bitz and boxes this year, and haven't put much work in besides decoloring. I'd say, 1500-2000 pts SM, at least a third built (maybe more, but I'll probably make some minor conversions), But I want them painted before fielding them in public.
about half of my raven guard is just primed (3 tac squads, 1 assault squad, 3 scout squads)
I have 2 rhinos, 3 whirlwinds, 2 vindicators, 1 land raider redeemer, 2 land speeders, 4 scout bikes, 4 bikes, 1 assautl bike, and my ironclad drednought just primed
for my orks about 80% just primed only (about 1200 pts)
Space wolves 90% primed only (about 750 pts)
for my Imperial guard about 70% primed only (1200 pts)
and my grey knights about 60% just primed (1000 pts)
Currently have 6 marines and a Pedro-counts-as in process, all primed black awaiting basecoats, a Predator needing detailing, and 3 plastic librarians waiting for me to get around to finding arms/weapon options for them. Everything else painted to tabletop standards
Being married helps somewhat in this regard, I'm not allowed to buy more toy spacemen until I've finished the ones I've got =D About to order 2 Razorbacks, a Whirlwind, a Dev squad, and a command squad, which will likely take me about 2-3mo to paint up
I have a painted Dark Angels 3rd company (112 marines, 2 Preds, 1 Vindi, 4 LR's) and a painted Guard Platoon (75 Guardsmen, 3 Heavy Weapon teams, 1 Chimera, 1 Leman Russ, 1 Sentinal). So those two armies make about 10% of what I currently own, leavy a shirt-load of stuff left to paint, including about 6000pts of High Elves.
Cheers,
Jono
Oh my Emperor.... I have well over 6K painted, but.... having said that, I have a LOT UN-assembled or unpainted.
Lets see.....
5 baneblades,
1 shadowsword
5 land raiders
38 bikes
5 land speeders
65 terminators
90+ space marines
30 scouts
3 dreadnoughts
and that's just off the top of my head. I"m sure I'm leaving out tihngs... like one of the new dreads, the flying land raider, and others.
just my thoughts
Well, I too have been playing since RT days. I have over 30k points of marines painted but also have about another 10k to paint including (but not limited to......) the following - 3 vindis, 2 TFCs, 4 assault squads (to get me up to 10 ;) ), 30 termis, 4 razorbacks, 4 LRs......and loads more....sigh
I have about 6k of guard to paint and put together, 5k of dark elves for fantasy, 5k of OnG and 6k of Empire to finish and add to the 3k I already have painted.
I am another that refuses to play with unpainted figures.
I have a store room especially for my figures and there seems to be no end in sight. As soon as I finish painting a squad I just go out and buy another......sigh.....need professional help I think.....
