Metal Sprey Paint
Im looking for spray paint that is similar to Boltgun mental, Any idea's?
I know Army Painter has one but they are always out of stock.
Options?
I also live in the USA if that helps.
If it is for miniatures as small as infantry, I don't think you'll have much joy, unless it is a proper 'for miniatures' one. The metallic particles are usually quite large as they are not for the 30mm scale, and metal paint takes a bit of blowing to get out of the can, so it usually comes out thick. Which will clog your mini very effectively.
If you are doing big terrain pieces, then it might work and should be available from hardware or arts and crafts stores.
If AB is a good product, you might just have to order it and then wait -_-
