Basing bikes...?
When bikes didn't have bases, I based mine anyway. They were always falling over. Of course these were the Ravenwing bikes with metal components, but depending on the pose or just where they are standing on the table (uphill) you'll probably have the same problem.
It also ties them together with all the other models of the army. It always bugged to have normal bases, titan bases (flat 60mm bases), clear flying stands and non based models next to each other.
https://bolterandchainsword.com/topic/235589-basing-bikes/#findComment-2837374
I used 60mm round bases for some chaos bikes that I extended the wheel base on, this meant that they would no longer fit on a cavalry base. However this was before the snazzy "bike base" came into existance. I'd use them for the normal bikes and stick attack bikes on the 60mm rounds. Incidentally the 60mm bases did give me LOADS of room for base detailing, each model became like it's own mini-diorama.
Also there is like no room leftover on a rectangular cavalry bases, which looks stupid.
https://bolterandchainsword.com/topic/235589-basing-bikes/#findComment-2841330
I actually used a normal base under the wheel on the attack bike. I kind of like the effect, but I can understand that it looks a little goofy to most other people. Never seen anyone else do it. So, the bike itself has an oval, and then the wheel on the sidecar just has a normal sized base right under it. I tend to think of bases like a little air bubble of scenery, so in my head it makes sense for anything that would touch the ground to have one to "float" on.
https://bolterandchainsword.com/topic/235589-basing-bikes/#findComment-2841342
