How to make alcolytes with Stormbolters?
GOFADK
I was thinking of using some Necromunda figs to make SoB Preachers and confessors, they may work for Acolytes as well.
The storm bolters from the marine commander sprue might be the way to go. The hand appears to be closer to guard sized.
What I did to get storm bolters for my sisters was to take 2 bolt pistols and file them so they fit together smoothly.
That was after trying various storm bolter & bolter bits to find the right scale.
Also there is a great difference in scale between the actual SB bits.
2 bolters is larger than the immolator SB, which is bigger than the land raider SB.
And the old metal GKPA model SB is smaller than the 2 pistols that I finally decided on.
I have not compared it to the new GKPA SB.
It ends up being just slightly smaller than the official sister SB, but doesn't look stupid if the model is holding it in one hand.
Also unless you don't play imperials you should have tons of these in you bits box... Free beats EBay.
What I did was to make them from the ground up using DE bodies, arms & legs & various heads from my bitz box. I used AoBR Terminator SBs w/ the drums replaced by twin boltgun magazines & put bolter handguards in front.
Here's a pic:
http://i184.photobucket.com/albums/x84/red_starrise/40K/Sisters/CIMG5007.jpg
