dizzy-xc Posted August 5, 2011 Share Posted August 5, 2011 Says One Landspeeder may equip a typhoon, and the next entry says One not equipped with a typhoon can have an assault cannon. Does this mean the whole squad of 5x speeders can have either or? Or is it that only 2x of the speeders can be equipped in this fashion? Thank you. Edited for command squad option. Link to comment Share on other sites More sharing options...
Lord Melvin Posted August 5, 2011 Share Posted August 5, 2011 From the way it's worded I would assume that out of the Five(5) total, you can have One(1) of each. So One(1) land speed may be upgraded to a Typhoon. Of the Four(4) left over that are not Typhoon's, One(1) may take an Assault Cannon. Link to comment Share on other sites More sharing options...
Isiah Posted August 5, 2011 Share Posted August 5, 2011 Lord Melvin has it right. Link to comment Share on other sites More sharing options...
dizzy-xc Posted August 7, 2011 Author Share Posted August 7, 2011 Ok, thank you. But the same is not true of the command squad? The choices seem to allow me to equip one veteran with a Melta and also give the same veteran a Banner. Link to comment Share on other sites More sharing options...
timmytool Posted August 7, 2011 Share Posted August 7, 2011 Ok, thank you. But the same is not true of the command squad? The choices seem to allow me to equip one veteran with a Melta and also give the same veteran a Banner. yes that's right you can do the weapon upgrade then upgrade the recipients status, but not the other way around. Note you could upgrade his bolter to a power weapon then make him a standard bearer and he would still get the +1 attack for 2 CC weapons, because they are extraordinary individuals! Link to comment Share on other sites More sharing options...
