Dreadnought assaulting a Trygon...
Can someone (numerous people would be helpful) just confirm for me:
A dreadnought does NOT have to take a dangerous terrrain test when assaulting a trygon as it IS a vehicle.
And although it moves like infantry this has absolutely nothing to do with the trygons ruling for making non-vehicle models take a dangerous terrain test.
A have money waging on this and I'm pretty sure I'm right.
https://bolterandchainsword.com/topic/235855-dreadnought-assaulting-a-trygon/
Trygons are not vehicles. Also, you don't have to make a Dangerous Terrain test simply to assault a vehicle, so why would it be any different for a Monstrous Creature?
If you're referring to a Trygon under the aegis of a Venomthrope's Spore Cloud, then any non-vehicle unit assaulting the Trygon would have to take a Dangerous Terrain test. This does not includes dreadnoughts, though vehicles normally do indeed take Dangerous Terrain tests (the rules for this are on page 57 of the BRB). So, the Dreadnought would not have to pass the Dangerous Terrain test, and its initiative would also not be lowered to 1.
Basically, you're right but not for the reason you gave.
"Walkers move in exactly the same way as infantry," (BRB pg73), but Spore Cloud clearly states, "non-vehicle enemy model ..." (C:T pg45) A dreadnought is a vehicle, regardless of the fact it moves as infantry, and is therefore unaffected by that portion of the rule.
[EDIT: Seahawk is a ninja. :ph34r: ]
Obviously, I know trygons aren't vehicles... i was referring to the dreadnought. (I thought this was pretty clear as the sentence opened with the words 'A dreadnought...' and not 'A trygon') And yes, I'm talking about the spore cloud thing.
I also know vehicles do take dangerous terrain tests when entering dangerous terrain... but thanks for pointing that out.
the question was in regards to a dreadnought assaulting a trygon.
Dan VK understood completely and confirms that I'm right for the right reasons.
I don't have a 'nid codex (hence why I couldnt name the rule in my original post) and only had a quick look at the rule when my opponent demanded my dreadnought take the test. To which I replied 'I think you're talking out you're behind'
Seahawk and Dan VK got here first and they're on the money.
The Dread is a vehicle; if the Trygon's rule specifies "non-vehicle models are affected", then he's not affected. Cut and dry. That the Dread "moves like a vehicles" has on bearing here; the ability's target set is clearly defined. It doesn't say "those who move like infantry take checks"; it says "non-vehicle units take checks".
Here is the better question "Why is your Dread assaulting a Trygon" Unless you have blood talons and furious charge (or at least blood talons), or the Tryon has only like 1 wound left, your dread is going to die more than likely.
This question is more for the tactics board. :( Not that I don't agree with you...but then, if the Dread were the only thing in range and I wanted that thing to die...and really, what Dread would balk at the chance to charge such a behemoth? The Emperor demands its blood...
The Emperor should employ His vast psychic powers to determine what on earth possessed GW to give Monstrous Creatures 2d6 armour pen then. Dreadnought v MC is basically a suicide mission. Really annoys me as I often play against either Tyranids or Chaos, both of which have lovely MC's that are all too happy to rip up my dreadnoughts.
It was a death company dread. It ripped his trygon to pieces.
His trygon was close to a venomthrope hence the spore cloud thing.
To me this whole thing is a no-brainer... a dread is a vehicle, it has armour values. It 'moves like infantry' for the pruposes of how the model the model moves in the movement phase. But i guess it goes to show how different people interpret rules.
Cheers for the replies anyway, the thread has been emailed to him.
surprised even a DC dread would Rip up a trygon unless it was already wounded (though the Venomthrope would be important otherwise you would have been I1), I'd have to check whether the defensive grenades would still effect the Dread. (3 attacks, hititng half the time, wounding 2/3 of that with rerolls, nets you 1 wound, then you get to attack again, but wounding 6 times would be tough, the Trygon hits back with 4 (I think, it might be 5) S 6 + 2d6 hits, with rerolls to hit.
With a Normal Furiouso
3/1 attacks 2/3 hit 3/4 wound 3/2 wounds
3/2 bonus attacks 2/3 hit 3/4 wound 3/4 bonus wounds.
3/4 bonus attacks 2/3 hit 3/4 wound 3/8 bonus wounds. (lets stop here since its below 50%)
~2.6 Wounds (21/8 for those of us that like fractions)
4/1 attacks 1/2 hit 3/4 wound 3/2 wounds
3/2 bonus attacks 1/2 hit 3/4 wound 9/16 bonus wounds.
9/16 bonus attacks 1/2 hit 3/4 wound 27/128 bonus wounds. (lets stop here since its below 50%)
~2.2 Wounds (This fraction is a bit too much for me to bother working out.)
Its really not a great match up but try rolling through it a few time you'd be surprised.
Where are we getting 3 attacks from?
I make it 5: 3 basic, +1 for having a pair of talons (in brackets on profile) +1 for charging. Furious charge gives him +1 strength and +1 initiative on first round..
Hitting on 4's, wounding on 3's with re-rolls. Then additional attacks. I scored 5 wounds and the trygon was done. Hed already took a wound.
He didnt utilize any defensive grenades if he had any.
Doesnt always have Furious Charge. I admit I didnt put the charge bonus in there but that is because the Trygon has defensive grenades when in a venomthrope bubble which does apply to the dreads. So the first set of numbers is the standard dready without FC. The second is the Death Company which I didnt even think about FC on. It is a quick adjustment though.
DC Dready
4/1 attacks 1/2 hit 8/9 wound 16/9 wounds
16/9 bonus attacks 1/2 hit 8/9 wound 8/9 bonus wounds.
8/9 bonus attacks 1/2 hit 8/9 wound 32/81 bonus wounds. (lets stop here since its below 50%)
~3 Wounds (248/81)
