mcpolle Posted August 8, 2011 Share Posted August 8, 2011 Hi brothers, I am about to start up in a campaign, where we start with 750 points, And the initial points will be built up on over the next couple of months, But as the initial points have to be carried over to the next 1000points, have to make sure I start off properly. So whats a good 750 point starter??? Polle Link to comment https://bolterandchainsword.com/topic/235891-starting-campaign-750points/ Share on other sites More sharing options...
hendrik Posted August 8, 2011 Share Posted August 8, 2011 2 units of grey hunters, a rune priest and some long fangs sound like a good start Link to comment https://bolterandchainsword.com/topic/235891-starting-campaign-750points/#findComment-2841550 Share on other sites More sharing options...
Simo429 Posted August 8, 2011 Share Posted August 8, 2011 If you can add men to existing troops in the later phases I would go with small units and then plump them out later on, at small games the rifleman dread is a good bet because there won't be much heavy armour and he is very accurate. If not I would go with Rune priest -110 Chooser Living Lightning and Murderous Hurricane 3 wolf Guard - 114 2 with power fists and combi meltas 1 with a power sword grey hunter squad x 8 - 185 Wolf Standard Mark of the wulfen Melta Rhino grey hunter squad x 9 - 200 Wolf Standard Mark of the wulfen Melta Rhino Long Fangs x 6 - 140 5 x Missile Launchers That comes to 749 and leaves you good scope to add more FAO Mods- never sure on the rules of putting lists with points on here, I think you are OK if you don't put points costs for individual upgrades, if not apologies. Link to comment https://bolterandchainsword.com/topic/235891-starting-campaign-750points/#findComment-2841554 Share on other sites More sharing options...
mcpolle Posted August 8, 2011 Author Share Posted August 8, 2011 thx for that, will def, look inti that list polle Link to comment https://bolterandchainsword.com/topic/235891-starting-campaign-750points/#findComment-2841564 Share on other sites More sharing options...
