Seahawk Posted August 10, 2011 Share Posted August 10, 2011 Seems stupor simple, but if the scenario doesn't allow Infiltrate, can that unit still use the Outflank ability? Basically the same...if a unit with Infiltrate deploys in its dedicated transport, it cannot Infiltrate. Can it still Outflank? Link to comment Share on other sites More sharing options...
thade Posted August 10, 2011 Share Posted August 10, 2011 I don't have my rulebook on hand; Outflank is a special use of Infiltrate, no? i.e. the Outflank ability is explained in the Infiltrate text. (Or is it in the Scout text?) If how I remember it is accurate, here's my take: If you have Infiltrate, you have the Outflank rule. If you can't Infiltrate, you can still Outflank (you don't need to be placed sneakily on the table during deployment to deploy from the side of the table later). I believe that locally (to me) the TOs are allowing Outflank in that scenario. Link to comment Share on other sites More sharing options...
Grimtooth Posted August 10, 2011 Share Posted August 10, 2011 Outflank is not part of the USR description other then to tell you that Scout and Infiltrate also confer the special outflank move. Outflank is described in Reserves and such. Link to comment Share on other sites More sharing options...
greatcrusade08 Posted August 10, 2011 Share Posted August 10, 2011 just becuase a mission doesnt allow infiltrate doesnt preclud the model/unit from having it as a USR. when you place them in reserve a model with infiltrate USR may outflank (chosen/declared at the time of reserving them) Link to comment Share on other sites More sharing options...
DarkGuard Posted August 10, 2011 Share Posted August 10, 2011 The wording is this: Infiltrate also confers a special outflank move to unit of infiltrators that are kept in reserve. I'd say, looking at that, that I'd agree with what's been said. Infiltrate is a USR that confers another ability. Outflank itself is different to Infiltrate in that it occurs in Reserve, rather than deployment before the game. In my mind, if you can't Infiltrate, you can still use your ability to Outflank, unless that is specifically prevented as well. Link to comment Share on other sites More sharing options...
Seahawk Posted August 10, 2011 Author Share Posted August 10, 2011 Good enough for me. My only continued contention is with the 'Ard Boyz scenarios, (ie, whatever comes out of GW's :D ). It lists all of the special rules, including outflank. In the 2nd scenario, it specifically leaves out Outflank...would that then deny anyone from using it? Link to comment Share on other sites More sharing options...
Grimtooth Posted August 10, 2011 Share Posted August 10, 2011 Not in my opinion. Being able to outflank is not dependent on being able to Infiltrate or Scout for that matter. Link to comment Share on other sites More sharing options...
Dan VK Posted August 11, 2011 Share Posted August 11, 2011 My only continued contention is with the 'Ard Boyz scenarios, (ie, whatever comes out of GW's :) ). It lists all of the special rules, including outflank. In the 2nd scenario, it specifically leaves out Outflank...would that then deny anyone from using it? As far as I know, tournament rules, even for GW sanctioned tournaments, have no bearing on the rules as they are used outside of the tournament. The scenarios are non-standard, so I would not rely on them as an accurate representation of the rules. :D Kind of like FAQs. ;) Link to comment Share on other sites More sharing options...
DarkGuard Posted August 11, 2011 Share Posted August 11, 2011 My only continued contention is with the 'Ard Boyz scenarios, (ie, whatever comes out of GW's :P ). It lists all of the special rules, including outflank. In the 2nd scenario, it specifically leaves out Outflank...would that then deny anyone from using it? If Outflank is included in all but one, then that suggests one of two things. Either it's a mistake and they'll let you know. Or they've purposefully left it out and you won't be able to use it. I feel the context of the scenario would help as well, sometimes there are times when you simply can't Outflank, either because of terrain, environment, opposing armies, time etc. Link to comment Share on other sites More sharing options...
Jacinda Posted August 12, 2011 Share Posted August 12, 2011 With the spearhead deployment, I think it was left out on purpose. Ask the TO when you sign in. Chances are they are well aware of the wording by now since it is all over the webz and they will have a ready answer. Link to comment Share on other sites More sharing options...
Seahawk Posted August 12, 2011 Author Share Posted August 12, 2011 Ah but here's the catch Jacinda...I am the TO ;). I just want to be fair to the players is all. Link to comment Share on other sites More sharing options...
ShinyRhino Posted August 12, 2011 Share Posted August 12, 2011 Our shop is playing it as "no outflank in Scenario 2." The Ard Boyz missions are a vaccuum-sealed environment, and the omission of Outflank from that scenario, especially after the update that put Seize the Initiative back into all three scenarios, is pretty telling. Link to comment Share on other sites More sharing options...
Seahawk Posted August 12, 2011 Author Share Posted August 12, 2011 That's what I figured as well. Link to comment Share on other sites More sharing options...
