EmbattledSoul Posted August 13, 2011 Share Posted August 13, 2011 ive already sanded the flat surfaces, washed them with abrasive cleaner... now this is where im torn. do i pin a model to them and prime/paint both at the same time? or would it be easier to prime and paint each seperate, then attach the model? Link to comment https://bolterandchainsword.com/topic/236236-dragon-forge-bases/ Share on other sites More sharing options...
maverike_prime Posted August 13, 2011 Share Posted August 13, 2011 when I built my New version of Abaddon I used a Dragon Forge base. I found it was tricky to prime the model but that's more because of the model relative to the base. the Way I build the model it had a lot of "openess" to it, so you had the arms over the body and the cloak over the legs and so forth. What model are you putting on the base? Link to comment https://bolterandchainsword.com/topic/236236-dragon-forge-bases/#findComment-2846425 Share on other sites More sharing options...
EmbattledSoul Posted August 13, 2011 Author Share Posted August 13, 2011 i bought 41 of them 30 25mm bases, 10 40mm bases, and one 60mm base... 20 tac marines and 10 sternguard on the 25mm, 5 assault termies and 5 tac termies on the 40mm, and a dread on the 60mm. Link to comment https://bolterandchainsword.com/topic/236236-dragon-forge-bases/#findComment-2846434 Share on other sites More sharing options...
Kurgan the Lurker Posted August 13, 2011 Share Posted August 13, 2011 You can set the pin hole then pin the model to a soda bottle top while you paint it. Paint the base separate and then rejoin them when finished. Link to comment https://bolterandchainsword.com/topic/236236-dragon-forge-bases/#findComment-2846443 Share on other sites More sharing options...
