Is there a sword like this?
Simple question. Is there a sword bit with a hilt like the one in this image?
http://i14.photobucket.com/albums/a316/maverike_prime/Warhammer/blood-reaver_cover.jpg
I was thinking dark Elves, and I saw the Lord on Dragon parts and looking at the matching swords from that kit.
Hoard O' Bits Image.
But the hilt isn't quit right. Is there a sword bit with the winged hilt like that? If not, anyone have a suggestion for converting it?
https://bolterandchainsword.com/topic/236330-is-there-a-sword-like-this/
I haven't time to do so myself, sadly, but my first inclination would be to dig extensively through the WH Fantasy kits...perhaps some combination of Chaos Warrior/Empires/Dark Elves hits will do the trick? I wouldn't be surprised if there was a HE hilt somewhere with wings on it, and you can get a tiny little skull somewhere, I'm sure. I know the new GK Termie kits are dripping with them. :)
I thought maybe the Dragon Princes of Caledor or the Blood Knights or the Cold one Knights. Searches turned up some nice swords there but not the same as what you are after. Also checked some Chaos Marine and specifically Night Lords stuff. Couldn't find much either at forgeworld of GW proper.
http://www.bitzbox.co.uk/
http://www.thecombatcompany.com.au/shopDis...ion+Accessories
Same kind of place as that Hoard o Bits you found but you can search them.
Well, if I recall thats actually a Blood Angle blade, so it wouldnt be bat-wings you'd be looking for.
It is indeed a Blood Angels blade, Aurum i believe is the name, meaning Gold in latin (i think, i'm half asleep..), which suits the blade very well indeed, must say, good idea ADB.
I haven't seen any quite like that though you could check the WFB Vampire counts and see if they may have something. I did make one with an aquila eagle from a space marine sgt. Banner pole top, a power axe handle and a tooth from a broken comb that had a diamond cross section, it was transparent red and I liked the idea of a crystal blade. Some bits might give you something closer to what you are looking for.
