Inaspin Posted August 15, 2011 Share Posted August 15, 2011 I am tinkering around to change my list, and because it doesn't say otherwise, can a Razorback move 18" (fast) and then deploy troops? Also, can terminators move and fire the cyclone missile launcher? Don't worry I am not trying to put them in the Raz <_< . Link to comment https://bolterandchainsword.com/topic/236373-couple-questions/ Share on other sites More sharing options...
Claws of Corax Posted August 15, 2011 Share Posted August 15, 2011 A fast transport can move 12" and disembark troops, or 18" and not disembark the unit. Pg 70 (I think) of the rulebook "Passengers may not embark onto or disembark from a fast vehicle if it has moved (or is going to move) flat out in that Movement phase" As for Terminators, they have the relentless special rule, allowing the model to fire heavy weapons after moving and still charge. "Relentless models can shoot with rapid fire and heavy weapons counting as stationary, even if they moved in the previous movement phase, and are also allowed to assault in the same turn they fire them." Hope this helps. Claws Link to comment https://bolterandchainsword.com/topic/236373-couple-questions/#findComment-2847848 Share on other sites More sharing options...
Brother_Byhlli Posted August 15, 2011 Share Posted August 15, 2011 Also, can terminators move and fire the cyclone missile launcher? Don't worry I am not trying to put them in the Raz :P . Not only can they move and fire the cyclone missile launcher, but they can move, fire the cyclone missile launcher and that model's stormbolter and then the entire unit can still charge. Link to comment https://bolterandchainsword.com/topic/236373-couple-questions/#findComment-2847908 Share on other sites More sharing options...
Inaspin Posted August 15, 2011 Author Share Posted August 15, 2011 Thanks... I am midway through painting the terminator bodies, before I add arms. Three thunderhammers and two lightning claws... Link to comment https://bolterandchainsword.com/topic/236373-couple-questions/#findComment-2848374 Share on other sites More sharing options...
Brother_Byhlli Posted August 15, 2011 Share Posted August 15, 2011 Thanks... I am midway through painting the terminator bodies, before I add arms. Three thunderhammers and two lightning claws... You can't have thunder hammers or lightning claws in a unit with a cyclone missile launcher. Link to comment https://bolterandchainsword.com/topic/236373-couple-questions/#findComment-2848377 Share on other sites More sharing options...
Inaspin Posted August 17, 2011 Author Share Posted August 17, 2011 Should have said, I am painting 2 units, ranged and assualt, hammer and tongs... Walking or land raiders will be the next question... Link to comment https://bolterandchainsword.com/topic/236373-couple-questions/#findComment-2849685 Share on other sites More sharing options...
Brother_Byhlli Posted August 17, 2011 Share Posted August 17, 2011 Should have said, I am painting 2 units, ranged and assualt, hammer and tongs... Walking or land raiders will be the next question... Depends on the unit. If they have guns, there's little point in putting them inside a box where they can't shoot anything. If they have no guns, they're gonna get shot up as they lumber across the board. My opinion, anyway. Link to comment https://bolterandchainsword.com/topic/236373-couple-questions/#findComment-2849722 Share on other sites More sharing options...
