Dumb..Stormraven capacity question.
Brother Paen
Thanks guys, I was worried about the dread, didn't know if it went against two units using a transpo at the same time.
So we're clear, it absolutely does go against two units using a transport at the same time.
However, the Stormraven expressly allows you to carry two units at the same time: "one unit of up to 12 models in its cabin, plus a single Dreadnought in its rear grapples".
Although not asked by the OP it should be noted that the Stormraven bends rules even further by expressely allowing units with jump packs to be transported, albeit at the cost of 2 capacity for one model (Allowing for 6 JP marines to be transported)
Claws
