GKT Loadouts
Borinar
I am stuck between the following two load outs and was hoping to get some assistance with my decision.
10 Terminators, 4 Demon Hammers, 2 Psycannon/Halberds, 4 Halberds.
Split in the following way:
Demon Hammer
Demon Hammer
Halberd/Psycannon
Halberd/Psycannon
Halberd
Demon Hammer
Demon Hammer
Halberd
Halberd
Halberd
My other option is to drop a Hammer from each 5 man for another halberd.
I am also stuck with whom to designate as the Justicar, My initial thought was to pick a Halberd from the second Group however, I could choose to Master Craft his weapon and I believe I would want the Demon Hammer MC'd before a halberd.
Decisions, Decisions...
https://bolterandchainsword.com/topic/236525-gkt-loadouts/
Here is how I currently run mine at 10 strong -
Justicar - halberd & stormbolter
5x halberd & stormbolter
2x daemonhammer & stormbolter
2x halberd & psycannon
- psybolt ammo
Here is how I split them into combat squads -
1) Justicar, 2x halberd & stormbolter, daemonhammer & stormbolter, halberd & psycannon
2) 3x halberd & stormbolter, daemonhammer & stormbolter, halberd & psycannon
I like the psybolt ammo since I play against IG a lot and you can crack their chimeras fairly easy with side shots which is fairly easy to do teleporting a squad and using a servo skull.
G :HQ:
https://bolterandchainsword.com/topic/236525-gkt-loadouts/#findComment-2850503
I would go with 2 psycannons, 2 Daemonhammers, and 8 halberds.
Split up into 2x5 GKT squads each squad would have the following loadout.
Psycannon+Halberd
3x Halberd
Daemonhammer
I would make one of the halberds the justicar.
I recommend taking more halberds over more daemonhammers because of the lack of stormshields. Without the durability of being able to fall back on a 3++ save, the goal should be to kill as many of the enemy unit as possible each turn before they even get the chance to hit back.
The problem with giving the Justicar a Daemonhammer in order to MC it is that if you happen to perils while trying to cast hammerhand or activate the squads forceweapons then there is a good chance that one of your daemonhammers just died. Making the justicar one of the halberd users still gives you plenty of other halberds left in the squads in case of something like that.
https://bolterandchainsword.com/topic/236525-gkt-loadouts/#findComment-2850506
I am going to go WAY out on a limb here and agree with what a bunch of people are saying:
Psycannon+Halberd
3x Halberd
Daemonhammer
https://bolterandchainsword.com/topic/236525-gkt-loadouts/#findComment-2851283
