Plastic Cutters
H4L
I am looking for some :cuss plastic cutters :cuss.
Needs to be able to cut/saw threw 1-2 cm thick of plastic.
For instance, I have 1 5 gallon EtOH plastic jug i want to cut the sides off of and 1 pop plastic delivery tray, again cut the sides off.
http://www.houseofcans.com/images/products/15532.jpg
http://www.flickr.com/photos/37044491@N00/119524634/
https://bolterandchainsword.com/topic/236876-plastic-cutters/
Cutting polyethylene and other soft, thermoplastics with power tools will make the plactic melt and gum up the blades. You would be better off using a simple box cutter for that. For the more rigid stuff like styrenes and resins, you should have no problem with using a jigsaw.
Jigsaws will kick back when cutting stuff like this, so you will need to be extremely careful. A dremel will work, but you can get away with a standard saw as well. Xuron cutters are also very good, but on the high side...
http://www.xuron.com/industrial/shears.htm
I actually had a pair of these bad boys sitting around (I use them to cut models from spruce). I didn't think they would be strong enough; I gave it a try this morning and sure enough it went threw it nice and easy. It's a bit slow, as the cutting edge is about 1cm and I need to get threw about 2meters...
A reinforced cutting wheel on a Dremel run at MINIMUM speed (5000 rpm) will work if you proceed in short cuts of about 5-10cm at a time. Pause for a couple minutes with the Dremel running between each cut. This allows the cutting head to air-cool during rotation, and prevents the melting effect.
