TWC Base size
ezekiel09
Either one (60mm or bike base) has become the standard. Anything under that is generally considered too small for a TWC (better suited for a fen. wolf).
Until GW releases an actual TWC model, it's debatable which is accurate, though many will argue that since Canis is in fact the ONLY TWC model, then his base should be acknowledged as the standard...with which others will rebuttal, stating that Fangir is the largest known Thunderwolf, so his base would naturally need to accommodate.
Also, fyi, there are several threads identical to this one. Should try searching the forums next time.
https://bolterandchainsword.com/topic/237437-twc-base-size/#findComment-2863375
Lots of things are bigger or smaller without affecting base size - yet Marines, Guardsmen, Tau and Termagaunts all share the same base.
Arjac is supposedly bigger than other Terminators, does he get a larger base as well?
Tsuro
https://bolterandchainsword.com/topic/237437-twc-base-size/#findComment-2863609
Tsuro
I didn't say it was MY argument... just one example that I've seen come up often. I'm perfectly happy putting mine on 60mm and calling it a day. Terminators used to be on the smaller base. They're now on the 40mm base (likely, in part, due to the redesign). Take from that what you will.
https://bolterandchainsword.com/topic/237437-twc-base-size/#findComment-2863635
