narius Posted September 1, 2011 Share Posted September 1, 2011 I've just started work on my Blood Angel Assault marine squad, as they have Jump packs I have modelled half on pins to show them flying/landing. Problem is the figures (No matter what glue) come loose really quickly and just end up spinning around! Has anyone else got a better way to get this effect? It'd be best my doing something now rather than when they're all painted. Cheers all! Link to comment https://bolterandchainsword.com/topic/237490-flying-assualt-marines/ Share on other sites More sharing options...
Sgt. Tiberus Satio Posted September 1, 2011 Share Posted September 1, 2011 I've always used green stuff in the hold of the foot, pack, or where ever you drill the marine and then green stuff the base to even out on top and underneath. Then insert the pin for both, adjust for height, place your model on the other end while he has green stuff in his drilled part, let dry and you're set. Link to comment https://bolterandchainsword.com/topic/237490-flying-assualt-marines/#findComment-2864007 Share on other sites More sharing options...
narius Posted September 1, 2011 Author Share Posted September 1, 2011 I've always used green stuff in the hold of the foot, pack, or where ever you drill the marine and then green stuff the base to even out on top and underneath. Then insert the pin for both, adjust for height, place your model on the other end while he has green stuff in his drilled part, let dry and you're set. Â Â Funnily enough I did Greenstuff it in the base end, didn't think about the foot end. Link to comment https://bolterandchainsword.com/topic/237490-flying-assualt-marines/#findComment-2864014 Share on other sites More sharing options...
Sgt. Tiberus Satio Posted September 1, 2011 Share Posted September 1, 2011 You wouldn't think it helps, but I did a bezerker model that was diving from the side shooting dual pistols and had him pinned in the air with greenstuff on all 4 points and that model has yet to ever see movement besides me picking him up. It just always helps to have a clay bonding substance for the pin to cling to. Link to comment https://bolterandchainsword.com/topic/237490-flying-assualt-marines/#findComment-2864017 Share on other sites More sharing options...
Hemal Posted September 1, 2011 Share Posted September 1, 2011 Also helps if you gouge out a furrow and bend the pin into a hiks shape at either end - this stops rotation as it prevents shear - glue and most bonding substances have awful shear strength as they are primarily designed to work in tension. Link to comment https://bolterandchainsword.com/topic/237490-flying-assualt-marines/#findComment-2864150 Share on other sites More sharing options...
thade Posted September 1, 2011 Share Posted September 1, 2011 Yea, that's what I do. I bend the pin a wee bit, apply glue, and gently jam it in there. Link to comment https://bolterandchainsword.com/topic/237490-flying-assualt-marines/#findComment-2864159 Share on other sites More sharing options...
Sgt. Tiberus Satio Posted September 1, 2011 Share Posted September 1, 2011 Yea, that's what I do. I bend the pin a wee bit, apply glue, and gently jam it in there. You gents will never be my apothicaries...... Link to comment https://bolterandchainsword.com/topic/237490-flying-assualt-marines/#findComment-2864163 Share on other sites More sharing options...
Jamafore Posted September 2, 2011 Share Posted September 2, 2011 That DOES sound rather painful, doesn't it? I, for one, am allergic to pain so I second that thought. ;) Link to comment https://bolterandchainsword.com/topic/237490-flying-assualt-marines/#findComment-2864775 Share on other sites More sharing options...
Schertenleib Posted September 4, 2011 Share Posted September 4, 2011 I know this is the easy way out, but I just glued mine to speeder flight posts. One point of contact under the pack, and one on the leg. Link to comment https://bolterandchainsword.com/topic/237490-flying-assualt-marines/#findComment-2866329 Share on other sites More sharing options...
narius Posted September 4, 2011 Author Share Posted September 4, 2011 I've done it!  I bought some Carbon rod from my local model shop (£2.50 per meter) Cut down wih razor saw and superglued in! Works AMAZING!!!! I'm even going to use this now for pinning as it glues like sh** to a shovel :P Link to comment https://bolterandchainsword.com/topic/237490-flying-assualt-marines/#findComment-2866507 Share on other sites More sharing options...
Tulkas Posted September 4, 2011 Share Posted September 4, 2011 Show! Link to comment https://bolterandchainsword.com/topic/237490-flying-assualt-marines/#findComment-2866766 Share on other sites More sharing options...
The Normish Posted September 4, 2011 Share Posted September 4, 2011 I know this is the easy way out, but I just glued mine to speeder flight posts. One point of contact under the pack, and one on the leg. That first one looks... um... uncomfortable. Link to comment https://bolterandchainsword.com/topic/237490-flying-assualt-marines/#findComment-2866803 Share on other sites More sharing options...
narius Posted September 4, 2011 Author Share Posted September 4, 2011 Show! Not the best of pics but it shows the size of the rod, The figures are rock solid ! Link to comment https://bolterandchainsword.com/topic/237490-flying-assualt-marines/#findComment-2866833 Share on other sites More sharing options...
Venerable Jazzman Posted September 5, 2011 Share Posted September 5, 2011 That first one looks... um... uncomfortable. The second one doesn't look a lot of fun either B) Â Re carbon rod - what thickness did you get, looks about 1.5 or 2mm? And do you think something narrower would hold them up or not? Link to comment https://bolterandchainsword.com/topic/237490-flying-assualt-marines/#findComment-2867398 Share on other sites More sharing options...
The Normish Posted September 6, 2011 Share Posted September 6, 2011 That first one looks... um... uncomfortable. The second one doesn't look a lot of fun either :P Â Re carbon rod - what thickness did you get, looks about 1.5 or 2mm? And do you think something narrower would hold them up or not? I would think narrower, because one that is too thick becomes too obvious. There's probably a balance to be found between strength and discretion. Link to comment https://bolterandchainsword.com/topic/237490-flying-assualt-marines/#findComment-2868685 Share on other sites More sharing options...
Sgt. Tiberus Satio Posted September 6, 2011 Share Posted September 6, 2011 2 of the modesl look like they're landing horribly wrong. The center looks a wee bit shaky on the landing, the other looks like he is launching backwards. Or perhaps that is just the way the picture is taken? Link to comment https://bolterandchainsword.com/topic/237490-flying-assualt-marines/#findComment-2868699 Share on other sites More sharing options...
narius Posted September 8, 2011 Author Share Posted September 8, 2011 I've used 2mm thick rod, I think there was 1mm which I'm going to use for pinning, the 2mm has the benefit of rigidity. For my army I wanted to make them sturdy, that's why I don't mind the rod being a bit thick. If you use the 1mm in small lengths I don't reckon you'd have any problems. Â I've tried to model 2 of the models flying with the other 3 just coming in to land, the guy with the powerfist is leaning a bit too much backward (That was my first attempt), I have 5 more but they're just running, It'll give the whole 10 man unit a bit of movement hopefully. Link to comment https://bolterandchainsword.com/topic/237490-flying-assualt-marines/#findComment-2870608 Share on other sites More sharing options...
Sgt. Tiberus Satio Posted September 8, 2011 Share Posted September 8, 2011 You could always take the rod out, patch up the hole with greenstuff and reapply the rod to a different position. Link to comment https://bolterandchainsword.com/topic/237490-flying-assualt-marines/#findComment-2870616 Share on other sites More sharing options...
narius Posted September 8, 2011 Author Share Posted September 8, 2011 TBH that rod ain't going anywhere lol... it's glued SO well! I might saw it off and do like you said though as I would prefer the rod to be on the foot! Link to comment https://bolterandchainsword.com/topic/237490-flying-assualt-marines/#findComment-2870630 Share on other sites More sharing options...
