Jorre Posted September 8, 2011 Share Posted September 8, 2011 I have been trying to freehand Some yellow blood drops on my marines to represent that they are in the second company. I'm not very good at it. Basically I have trouble making the bottom curved part of the drop. Also keeping them a consistent size is very difficult. Anyone got any pointers or tips for this kind of thing? Link to comment https://bolterandchainsword.com/topic/238023-freehand-company-markings/ Share on other sites More sharing options...
Brightguy Posted September 8, 2011 Share Posted September 8, 2011 First tip is practice. I'm not a great freehander, but I've done a bunch of symbols and you get better. If you're not confident, paint the symbol a bunch of times on a piece of cardboard or similar piece of scrap before you put it on your model. For consistent sizing, try to find reference points. I typically want the symbol to run about 2/3 of the way across the flat part of the shoulder pad. Having a clear picture of the size of the symbol you want helps. You can also mark out the extent before you paint with small dots to use as a guide. Start with a simple vertical line of the length you want and then fill it out to make the drop. Link to comment https://bolterandchainsword.com/topic/238023-freehand-company-markings/#findComment-2870468 Share on other sites More sharing options...
Taz Posted September 8, 2011 Share Posted September 8, 2011 To build upon Brightguy's advice, instead of simply a line, drawing a horizontal one near to the bottom in an inverted cross shape can help too. This will mark out the outer edge of the blood drop's bottom curve. From there, simply connect the edges of the horizontal line to the top and put a curve in the bottom and fill it out. If need be I guess I could go into MS paint and whip up a quick diagram, I suppose. Link to comment https://bolterandchainsword.com/topic/238023-freehand-company-markings/#findComment-2870506 Share on other sites More sharing options...
Smendrik Posted September 8, 2011 Share Posted September 8, 2011 What about other markings? Any tips for an Aquilla or the Flesh Tearer symbol? Link to comment https://bolterandchainsword.com/topic/238023-freehand-company-markings/#findComment-2870514 Share on other sites More sharing options...
ulllyssies0110 Posted September 8, 2011 Share Posted September 8, 2011 Go on Utube and Look up Awesome paint job blood angles, or flesh tearers. Link to comment https://bolterandchainsword.com/topic/238023-freehand-company-markings/#findComment-2870749 Share on other sites More sharing options...
Martyn Posted September 8, 2011 Share Posted September 8, 2011 For my drops, I use a thick piece of paper and cut out the drop. Then place it over the desired location and basically paint it in. Maybe it might help you brother. Link to comment https://bolterandchainsword.com/topic/238023-freehand-company-markings/#findComment-2870790 Share on other sites More sharing options...
Jorre Posted September 9, 2011 Author Share Posted September 9, 2011 Thanks for the pointers guys. If only I could stop playing space marine for a bit I might get a chance to try them out Link to comment https://bolterandchainsword.com/topic/238023-freehand-company-markings/#findComment-2870985 Share on other sites More sharing options...
Brother Nathan Posted September 9, 2011 Share Posted September 9, 2011 i hate free hand. and i play 5th co, have you noticed what we have to do on out sarges shoulders... grumble, lol. anyway for mine (well both shoulders as i have my chaper symbol a hawquise blood drop with lightening running down it) i doo a rough blood drop, trying to get the top point right first time. then when that drys i go round the outline with the colour of the pas to tidy it up and make it look a little bit more uniform. Realy id prefer to cast up a bunch of the death co pad that has a big flat blood drop in it but as i have over 100 marines im not gonna go back and redo them all... Link to comment https://bolterandchainsword.com/topic/238023-freehand-company-markings/#findComment-2871510 Share on other sites More sharing options...
