Primarch015 Posted September 9, 2011 Share Posted September 9, 2011 how do i get rid of it? just messed up my ragnar conversion with the varnish.... Link to comment https://bolterandchainsword.com/topic/238087-dusty-effect-from-varnish-spray/ Share on other sites More sharing options...
Bearingtheword Posted September 9, 2011 Share Posted September 9, 2011 :D Had that happen to my IG when I sprayed them. Was told that it was because the can had been kept outside (in the garage) and the temperature had exceeded the manufacturers recomended temp, which tends to happen during the summers here in nw Arizona (temps often exceed 120 degrees (f) from May through October.) Was also told the only thing I could do to fix them was to strip the paint off of them with simple green and to repaint them :) Since I had just sprayed about 40 models with it, I said screw it and did what I could to make them look dusty/dirty and rebased them with a desert looking base... One thing I did do that seemed to cut the look down was take a brush and some water and then brush the whole model (not the bases) with a wet brush. I noticed it had toned it down somewhat after brush each model 3 times, letting it dry between each brushing. Not sure if you'll get the same results or not. Good thing (if you can call it that) is that it sounds like you only had it happen to 1 model, so if you do decide to strip the paint off him and start over its not as bad as the 40 model prospect I was faced with. But I would definitely be sure to throw the can away so you don't use it again by mistake. Good luck and I hope the water method helps at least somewhat.... ~BtW Link to comment https://bolterandchainsword.com/topic/238087-dusty-effect-from-varnish-spray/#findComment-2871123 Share on other sites More sharing options...
Brother Nihm Posted September 9, 2011 Share Posted September 9, 2011 solution Link to comment https://bolterandchainsword.com/topic/238087-dusty-effect-from-varnish-spray/#findComment-2871144 Share on other sites More sharing options...
Primarch015 Posted September 9, 2011 Author Share Posted September 9, 2011 solution wow thanks a lot man Link to comment https://bolterandchainsword.com/topic/238087-dusty-effect-from-varnish-spray/#findComment-2871178 Share on other sites More sharing options...
