Abaddonshand Posted September 9, 2011 Share Posted September 9, 2011 Specifically, terminator armour or dreadknight armour? I believe that it doesn't, as this is armour, not wargear. In a game I played against another grey knight player, he tried to use it to take away my dreadknight's invulnerable save (failed to wound, so didn't work). In case this comes up again, I thought I should check it. Thanks Link to comment https://bolterandchainsword.com/topic/238114-does-the-vindicare-shield-breaker-work-on-armour/ Share on other sites More sharing options...
Elric the Silvercoat Posted September 9, 2011 Share Posted September 9, 2011 Wargear is anything that your model has on. Armour is wargear, weapons are wargear, genardes are wargear. So yes the Shield Breaker would pop the 3++ saves from Storm Shield for example. Link to comment https://bolterandchainsword.com/topic/238114-does-the-vindicare-shield-breaker-work-on-armour/#findComment-2871498 Share on other sites More sharing options...
Brother Valerius Posted September 9, 2011 Share Posted September 9, 2011 Armor is wargear, so it does remove an invulnerable save conferred by armor. Link to comment https://bolterandchainsword.com/topic/238114-does-the-vindicare-shield-breaker-work-on-armour/#findComment-2871500 Share on other sites More sharing options...
Chengar Qordath Posted September 9, 2011 Share Posted September 9, 2011 Thirding that armor is wargear; Terminators and Dreadknights both have their armor listed under the wargear heading in their army list entries. Link to comment https://bolterandchainsword.com/topic/238114-does-the-vindicare-shield-breaker-work-on-armour/#findComment-2871507 Share on other sites More sharing options...
Elric the Silvercoat Posted September 9, 2011 Share Posted September 9, 2011 The ones that get Inv Saves from Special Abilities are the ones that don't lose it from Shield Breakers like Ragnar Blackmane from Space Wolves and Mandrakes from Dark Eldar. Stuff like that. Link to comment https://bolterandchainsword.com/topic/238114-does-the-vindicare-shield-breaker-work-on-armour/#findComment-2871511 Share on other sites More sharing options...
thade Posted September 9, 2011 Share Posted September 9, 2011 This has an interesting (if very infrequent) side effect: if you hit a unit of Terminators, for instance, that is identical in load out (say they are all LC termintators) then whichever one takes and fails the save is suddenly different from the rest of the squad: he's in his own class now for wound allocation! I say "very infrequent" because I don't see a Vindicare effectively wasting a shot with this unless he's feeling very cheeky, has some sinister plan, or really has nothing else to shoot at. Link to comment https://bolterandchainsword.com/topic/238114-does-the-vindicare-shield-breaker-work-on-armour/#findComment-2871520 Share on other sites More sharing options...
Brother Valerius Posted September 9, 2011 Share Posted September 9, 2011 You know, I just noticed an interesting thing in the wording of the shield breaker... it says that "when a wound... is allocated to a model, that model loses any invulnerable saves... immediately." (emphasis mine) That means that the losing of the invulnerable save happens before saves are rolled, and happens even if the wound is saved against. I never really realized that before. Thade, you are of course correct about the terminator, but since he loses his inv save immediately (so no saving that way), and the wound is AP1, and he only has one wound, he's not likely to live long enough for it to matter. :) Link to comment https://bolterandchainsword.com/topic/238114-does-the-vindicare-shield-breaker-work-on-armour/#findComment-2871537 Share on other sites More sharing options...
thade Posted September 9, 2011 Share Posted September 9, 2011 Ha, fair point. Then this would only come up in the EXTREMELY rare situation where a player has a unit of Nobs (all of which have cybork parts) or a unit of Paladins (all of which are identically geared up). Purely academic on my part. Feel free to disregard me here. :) Link to comment https://bolterandchainsword.com/topic/238114-does-the-vindicare-shield-breaker-work-on-armour/#findComment-2871540 Share on other sites More sharing options...
JamesI Posted September 9, 2011 Share Posted September 9, 2011 You know, I just noticed an interesting thing in the wording of the shield breaker... it says that "when a wound... is allocated to a model, that model loses any invulnerable saves... immediately." (emphasis mine) That means that the losing of the invulnerable save happens before saves are rolled, and happens even if the wound is saved against. I never really realized that before. Thade, you are of course correct about the terminator, but since he loses his inv save immediately (so no saving that way), and the wound is AP1, and he only has one wound, he's not likely to live long enough for it to matter. :) The terminator could be in cover? Link to comment https://bolterandchainsword.com/topic/238114-does-the-vindicare-shield-breaker-work-on-armour/#findComment-2871545 Share on other sites More sharing options...
Elric the Silvercoat Posted September 9, 2011 Share Posted September 9, 2011 You know, I just noticed an interesting thing in the wording of the shield breaker... it says that "when a wound... is allocated to a model, that model loses any invulnerable saves... immediately." (emphasis mine) That means that the losing of the invulnerable save happens before saves are rolled, and happens even if the wound is saved against. I never really realized that before. Thade, you are of course correct about the terminator, but since he loses his inv save immediately (so no saving that way), and the wound is AP1, and he only has one wound, he's not likely to live long enough for it to matter. ;) The terminator could be in cover? Terminators in cover? What terminators are you running without Storm Shields? :D Link to comment https://bolterandchainsword.com/topic/238114-does-the-vindicare-shield-breaker-work-on-armour/#findComment-2871579 Share on other sites More sharing options...
Inquisitor Fox Posted September 9, 2011 Share Posted September 9, 2011 Granted everything the Inquisition does needs to be looked at in the vein of "It could be a plot..." I mean, we love Illuminating plots after all... ;) "I always think everything could be a trap... that is why I'm still alive..." - Prince Humperdink Sometimes it's nice to differentiate numbers, or to try and pick off things with invulnerable saves. Granted I'm not sure of which of those situations it could be right now. Usually I'm going for higher profile targets than Terminators. With the invulnerable save being eliminated as soon as the wound is assigned however, it makes it a little easier to carve through things like Hammernators or Lysander. Abaddon becomes a lot easier to take down as his invuln gradually reduces, though I can't remember how much of his is wargear and how much is daemonic gifts. It could be an excellent use of a Vindicare to gradually take down a Hammernator Assault Terminator unit. EDIT: Terminators in cover? What terminators are you running without Storm Shields? :D It could be the one or two lightning-claw terminators in the same unit... ;) Link to comment https://bolterandchainsword.com/topic/238114-does-the-vindicare-shield-breaker-work-on-armour/#findComment-2871580 Share on other sites More sharing options...
Brother Valerius Posted September 9, 2011 Share Posted September 9, 2011 You know, I just noticed an interesting thing in the wording of the shield breaker... it says that "when a wound... is allocated to a model, that model loses any invulnerable saves... immediately." (emphasis mine) That means that the losing of the invulnerable save happens before saves are rolled, and happens even if the wound is saved against. I never really realized that before. Thade, you are of course correct about the terminator, but since he loses his inv save immediately (so no saving that way), and the wound is AP1, and he only has one wound, he's not likely to live long enough for it to matter. ;) The terminator could be in cover? Terminators in cover? What terminators are you running without Storm Shields? :D No storm shield save, the loss of invulnerable save is immediate (before saves are taken). So yeah, cover is the only save you could take. That's unlikely, though. Link to comment https://bolterandchainsword.com/topic/238114-does-the-vindicare-shield-breaker-work-on-armour/#findComment-2871582 Share on other sites More sharing options...
Abaddonshand Posted September 9, 2011 Author Share Posted September 9, 2011 Thanks for clearing that up for me. I thought it didn't work on armour because when I played sisters a while back I used it on St. Celestine and the sisters player told me it didn't work on her. Link to comment https://bolterandchainsword.com/topic/238114-does-the-vindicare-shield-breaker-work-on-armour/#findComment-2871594 Share on other sites More sharing options...
BLACK BLŒ FLY Posted September 9, 2011 Share Posted September 9, 2011 Fool me once shame on you... fool me twice shame on me. ;) G :D Link to comment https://bolterandchainsword.com/topic/238114-does-the-vindicare-shield-breaker-work-on-armour/#findComment-2871601 Share on other sites More sharing options...
Drachnon Posted September 9, 2011 Share Posted September 9, 2011 Thanks for clearing that up for me. I thought it didn't work on armour because when I played sisters a while back I used it on St. Celestine and the sisters player told me it didn't work on her. It works half on St. Celestine. Celestine has 2 invunerable saves: A 4+ from her armour (which is wargear) A 6+ from shield of faith (which is a special rule) Since shield breakers only work on wargear she loses her 4+ inv save but retains the 6+. Link to comment https://bolterandchainsword.com/topic/238114-does-the-vindicare-shield-breaker-work-on-armour/#findComment-2871718 Share on other sites More sharing options...
GodwynDi Posted September 12, 2011 Share Posted September 12, 2011 Thanks for clearing that up for me. I thought it didn't work on armour because when I played sisters a while back I used it on St. Celestine and the sisters player told me it didn't work on her. It works half on St. Celestine. Celestine has 2 invunerable saves: A 4+ from her armour (which is wargear) A 6+ from shield of faith (which is a special rule) Since shield breakers only work on wargear she loses her 4+ inv save but retains the 6+. Or was it the old WH dex and she was gaining her invulnerable from spirit of the martyr? Even then it would remove her armor 4++, but that was rarely that important before. Link to comment https://bolterandchainsword.com/topic/238114-does-the-vindicare-shield-breaker-work-on-armour/#findComment-2873822 Share on other sites More sharing options...
BassWave Posted September 15, 2011 Share Posted September 15, 2011 Wait would a storm shield wielding terminator lose his 3+ invul as well as his normal 5+ at the same time, or does he need to get shot twice in order to lose both? Link to comment https://bolterandchainsword.com/topic/238114-does-the-vindicare-shield-breaker-work-on-armour/#findComment-2875980 Share on other sites More sharing options...
BrotherWasted Posted September 15, 2011 Share Posted September 15, 2011 He'd lose both. The rules specifically say the target loses "any invulnverable saves" that come from wargear. Link to comment https://bolterandchainsword.com/topic/238114-does-the-vindicare-shield-breaker-work-on-armour/#findComment-2876039 Share on other sites More sharing options...
ValourousHeart Posted September 17, 2011 Share Posted September 17, 2011 Although for the life of me I can't figure out why the vindicare doesn't know what the mob has known for years. Blow off their knee caps, that should slow down those wyches. Link to comment https://bolterandchainsword.com/topic/238114-does-the-vindicare-shield-breaker-work-on-armour/#findComment-2877911 Share on other sites More sharing options...
