radens Posted September 12, 2011 Share Posted September 12, 2011 1. If a squad fail their act of faith test, can they spend another faith point to try it again? 2. Canoness is going solo or with unit without act of faith rule - does she get +1 to acts of faith tests becouse she is "leading herself" 3. Canoness and Eclessiarchy Confessor are leading a battle conclave - do I get +1 or +2 bonus to act of faith test? Or maybe none? Link to comment Share on other sites More sharing options...
Grey Mage Posted September 12, 2011 Share Posted September 12, 2011 1) Yes, it would appear so. 2) I would say yes, though I think its a far less valuable use of your power in such cases. 3) +1 for being led is how I read it. Itd be cumulative with the +1 for having taking a casualty though. Link to comment Share on other sites More sharing options...
radens Posted September 12, 2011 Author Share Posted September 12, 2011 thanks, sounds fair. Link to comment Share on other sites More sharing options...
Marshal Wilhelm Posted September 12, 2011 Share Posted September 12, 2011 1. If a squad fail their act of faith test, can they spend another faith point to try it again?2. Canoness is going solo or with unit without act of faith rule - does she get +1 to acts of faith tests becouse she is "leading herself" 3. Canoness and Eclessiarchy Confessor are leading a battle conclave - do I get +1 or +2 bonus to act of faith test? Or maybe none? My answer to Sisters questions? ;) You can make quite a fluffy list via count-as with Marines :) Vulkan She'stan is full of sweet extra burny hot weapons. C:BA has Baals, and fast Razors, loaded with tl HF, of course. You can use Mephiston or the Sanguinor as Celestine. etc. So whilst I am being cheeky, I do actually believe, if the passage of time proves C:SoB to be frustrating, that count-as can provide a gaming solution. +++ But I will stop being naughty and help you with future questions :) Link to comment Share on other sites More sharing options...
Hiro_Protagonist Posted September 12, 2011 Share Posted September 12, 2011 1. If a squad fail their act of faith test, can they spend another faith point to try it again?2. Canoness is going solo or with unit without act of faith rule - does she get +1 to acts of faith tests becouse she is "leading herself" 3. Canoness and Eclessiarchy Confessor are leading a battle conclave - do I get +1 or +2 bonus to act of faith test? Or maybe none? 1. Currently as written I'd say yes. They should soon FAQ this though, if you can only attempt a psychic power once why should acts be any different? 2. No. The +1 is only if a Canoness has joined a squad, not for leading (which is listed seperately). 3. +1 only. The +1 for an Independant Character says "...at least one of the following..." not +1 "for each of the following" Link to comment Share on other sites More sharing options...
